Airtrek Turbo Gearbox
biao
Dear All Sifu,
i need all your advice and opinion.
i suspect my gearbox KONG already.
on yesterday i feel my car have jerking and have metal sound came out. first i suspect my turbo kong because when i step the pedal just have sound running low speed, release pedal sound more loud. jerking awhile then no more already.
so this morning i try again, same method when i step pedal just have sound,release same.
but when i go fast totally no sound came out. then i suspect is my gearbox kong. why i suspect because i try switch to pedal switch, gear 1,2,3 sound came out, change til gear 4 then no sound.
so this can proud is gearbox KONG? can repair? how much the cost? or change it? if change, change half cut condition or change the recon gearbox?
Dear All Sifu,
any one can advise?
if the gearbox really kong, it will turn to limp mode. u can only run on 3rd gear. but now all gear can engage, only sound then it might be the transfer gear or long shaft.. u have to get it check.. go to ah hwa in kinrara..
His location.....Perak....:smokin:
you means the mid-box?
actually is all gear can run, just only the 1st, 2nd and 3rd gear will have sound came out. sound like metal grinding.
and last night have happen on 1st gear look like slip when waiting traffic light cannot move.
Then come up to see Ah Wah.......lol:driver:
ya later will call him.
i just scare later is gearbox problem then need to change, suddenly dont know go where get it. because i need on the same day get the car. that's why i need confirm the problem then get the solution. now i have search the gearbox halfcut and recond.
better get the car for check first. sometimes not every error is a big issue.. sometime only atf not enuf so the gear changes slow and snapping.. better send your car there in the morning, get some fren to follow u, and if really need to get a set of gearbox u can drive to buy.. there are few halfcut shop to go for.. i counted its 4 shops around selangor. which 3 in puchong and 1 in subang for airtrek turbo parts.
there actually 1 more in kuala selangor and 1 in KL area. but these area are far from ah wah so not practical.
i already call ah wah. he confirm is the gearbox spoil. he say 1 of the gear spoil and make the sound grinding. so he suggest me change gearbox because cheaper and fast. and he say wait he find the gearbox just let me know.
i need some idea from you all.
option 1: buy a halfcut gearbox to change it
option 2: overhaul the gearbox
option 3: buy a rebuilt gearbox to change
which is better ?
which is better ?
3 is like 2, some will want your old gb in exchange.
For me if keeping the car, either 2 or 3, since overhaul means change new parts etc...
halfcut gb, don't know the history of it.....:smokin:
yup, the 3 is need my old gb in exchange. if 2 cost very high, some quote me 2k+
To me, All option can be considered..
option 1: buy a halfcut gearbox to change it makesure low mileage and good condition upon buying and this option is the lowest cost
option 2: overhaul the gearbox overhaul will cost higher since gear has faul but if got budget why not
option 3: buy a rebuilt gearbox to change this is like buying a recond gb which slightly lower cost than option 2 but need to makesure a good workmanship of recond gb and installation
option 4: buy a evo gta gearbox or evo manual conversion... :driver:
option 1: buy a halfcut gearbox to change it makesure low mileage and good condition upon buying and this option is the lowest costvery hard to confirm the mileage because have some already dismantle from the halfcut.the cost is just slightly lower than option 3.
option 2: overhaul the gearbox overhaul will cost higher since gear has faul but if got budget why notyup very high cost, no budget right now because happen so sudden.
option 3: buy a rebuilt gearbox to change this is like buying a recond gb which slightly lower cost than option 2 but need to makesure a good workmanship of recond gb and installationthis gearbox done by OTX from Semenyih
haha...never consider convert to manual
Halfcut gb very hard to tell mileage, that is why I mention don't know the history......lol
