Amt power cushion buffer
ZENSPEED
Amt power cushion buffer for coil spring
AMT POWER CUSHION BUFFER (for coil spring)
ADVANTAGE OF USING POWER CUSHION BUFFER
1. Rubber buffer can effectively solve the problem of springs weakness and recover the performance of the shock absorber.
2. Shock absorption effects felt in a mercedes benz car.
3. Protect shock absorber and suspension system to avoid oil leak.
4. The life of a normal shock absorber will be extended to more than 2 times.
5. Improve driving comfort and more stable during curve corner.
6. Improve braking efficiency.
7. Reduce noise and vibration during travelling.
8. Size for all type of car including lowered spring and adjustable.
10. Less sound and less maintenance for adjustable
Price for whole car RM90 for all size.
COD within klang valley(out of klang valley try call) and malacca
Installation location : My place near kelana jaya or your place.
Installation : Cheap and negotiable.
Installation including safety cable clip.
H/P :0162023768. Call or sms me anytime.
SizeA-gaping 47mm, thickness 13mm, diameter 173mm
SizeB-gaping 35mm, thickness 13mm, diameter 160mm
SizeC-gaping 27mm, thickness 10mm, diameter 131mm
SizeD-gaping 23mm, thickness 10mm, diameter 113mm
SizeE-gaping 15mm, thickness 10mm, diameter 112mm
SizeF-gaping 12mm, thickness 15mm, diameter 120mm
The above measuremnt for reference.
hey bro. for perdana?pls quote me the price including installation..
i"m using zerone adjustable
hi bro
quote me the price for civic fd1..currently using gab adjustable
thanks
Bump: what the material this buffer made from?
you got all size compatible including lowered spring? how about caldina gt4? currently using stock abs with Tanabe NF210 lowered spring.
Will this make the car higher?
padilo price is RM120. material rubber.
Bump:
qmk9133 my car is a ford tx3 also using lowered spring.
below size E and Size f mostly suitable for lowered spring
whether to make ur car higher or not. it depends ur coil spring design and how u adjust.
SizeA-gaping 48mm, thickness 13mm, diameter 175mm
SizeB-gaping 38mm, thickness 13mm, diameter 158mm
SizeC-gaping 28mm, thickness 10mm, diameter 133mm
SizeD-gaping 21mm, thickness 10mm, diameter 113mm
SizeE-gaping 15mm, thickness 10mm, diameter 113mm
SizeF-gaping 13mm, thickness 9mm, diameter 125mm
i can measure for u
Bump:
hi bro
thanks
Bump: bump bump bump
Bump: AMT POWER CUSHION BUFFER
8. Size for all type of car including lowered spring.
Price for whole car RM120 to RM130 depends on size.
Installation location : My place near midvalley or your place.
Bump: king jamez pm replied
Bump: improve handling
Bump: bump bump
bro. .what kind of material that thing use?? silicon or just plain rubber??
pm me best price for perdana sei... thanks
Amt power cushion buffer 6
suitable for those who use bugger rim. sometimes tyre will wear and tear while rubbing against the fender wall
Bump: Size for all type of car including lowered spring.
