AMSOIL DOMINATOR® Octane Boost
Comanche
Banned
AMSOIL DOMINATOR® Octane Boost (AOB) significantly increases engine response and power in all gasoline-fueled engines. Just one treatment reduces engine knock, improves ignition and helps fuel burn cleaner. DOMINATOR Octane Boost is the recommended octane boost for all high-performance off-road and racing applications. Most users find one 12-ounce bottle of DOMINATOR Octane Boost for 15 gallons of gasoline provides the ideal performance increase. DOMINATOR Octane Boost is also excellent as a lead substitute at the same treat rates in collector automobiles, older off-road equipment and pleasure vehicles.
What is "engine knock" and why does it matter?
"Knock" is an uncontrolled and explosive ignition of a hydrocarbon fuel, such as gasoline, in the combustion chamber. It causes a knocking or pinging sound, robs the engine of power and, left unchecked, causes serious engine damage. Fuel's tendency to knock is measured by its octane number. Lower numbers denote greater knock tendency; higher numbers denote greater knock control. Knock may be eliminated with the appropriate octane number.
AMSOIL PRODUCT WARRANTY
AMSOIL products are backed by a Limited Liability Warranty.
Improves performance
Removes carbon deposits
Maximizes power
Reduces engine knock
Improves ignition
Improves responsiveness
Helps fuel burn cleaner
I don't understand why not put the price instead of receiving tonnes of pm. It's just one same product.
