altezza rigidity problem.
220mph
want to know izzit me or this happen to every 1.
when i brake hard, corner hard, or go over the bump hard, my car will have sound of something beeing press or bend.its in the front and also mildly on the back. it sound like u apply lots of stress and pressure on the plastic dashboard. its our tezza not rigid enough? and does any 1know whats the weight distribution btween front and back for rs200?
i dont have such sounds...not sure abt other bros..
weight distribution is almost 50:50 or was it 60:40..
read it somewhere..cannot recall...but very good distribution tho..
other bros??
most probably your suspension set up is too soft to handly such pressure
it happened to me when i changed my suspension to softer trd sportivo, during hard cornering, the sound like a metal been bend appeared and all kind of funny sound
once i used back my adjustable set up, no more problem, and mind u my car has 3 points front upper strut, 2 points rear upper struct, 3 points front lower bracing and 4 points rear lower bracing from the begining
i guess, by changing to softer suspension set up disrupt the whole set up for my car
There are two possibilities:-
i) One or more of the dampers (ab-so-bah) are screwed
ii) A mis-aligned chasis due to some kind of accident
hmm.. altezza braking is top class i shall say. damper , i dont think so "still feel ok".
chassis perfect "check when i bought it from front to back by expert"..
want to know how it sound ? press hard with ur thumb or any finger on the dashboard of any part of the interior.. thats how it sound..
old car lah
when u buy a 2000 or 2001 car
old leh
mine also plenty of sound creakkkk here n thr a bit
just dun bother as long as the suspensions are fine....
oic green ...
mine cenkerik sound ada, tikus sound ada, kucing sound ada ... and sometimes huh, kentut sound pun also ada ... kakakakakaka
u wan better chassis response, go buy all the toms bars for the altezza.
get bigger anti roll bars n the front n rear struct bars....then ur chassis will behave nicely
