Altezza idle rpm
Y mine turn up to 500rpm only ah..some more d engine vibrating too.is there any thing wrong with timing..o probablybd eng mtg wear out d..
Something is wrong when the idle rpm is barely 500 on 2.0.
Engine mounting issue usually associated with loud engine sound intrusion into the cabin and vibration, regardless of engine speed where higher engine speed caused vibration too.
As mentioned by rayncc, start with tb cleaning. If you stay around KL area. Mr Alex in Desa Tasik or William at Trial Tuning Sungai Besi are the best person to find. Both are located less than 2km apart.
