Alpine DDDrive Component, V12 Expert Amp, DDDrive Woofer
ICE -In Car Entertainment
LazyCrazy
8,000 RPM
Dear all ICEer & Forumers!!!
I have few set of my ICE collection would like to sell.
Please read the desciption of the item and do call me if more info is needed.
Alpine DDDrive Highest End Component Set
Model : DDC-F17C
Complete Set :
1 Pair DDDrive Midbass
1 Pair DDDrive Biodyna Dome Tweeter
1 Pair DDDrive 2way Crossover Network
*Direct Import from Japan, NOT FROM HALFCUT
*ORIGINAL MADE IN JAPAN
*Superb sound quality!! Suitable for SQ tuning
Spec:
Power Handling - 200watts Max, 50Watts RMS
Impedance 4ohms
Frequency Response 35 - 35,000Hz
Sensitivity 90dB/W(1M)
Woofer Free Air Resonance 62Hz
Quote From Alpine Japan :
DDDrive (Dual Direct Drive) Magnetic Circuity
DDDrive System - Alpine is proud of the system in the world - is employed in both the wooferand tweeter units, thereby supressing distortion level by the magneticcircuit up to a value unable to measureand succeeding to realize a natural sound reproduction
Diaphragm
In the woofer, a fine hybrid mice diaphrgam which has high rigidness and high internal loss is used and in the tweeter, a BIODYNA-inverted dome diaphragm which has ideal characteristics in material available currently is used, thereby supressing the distortion by the diaphragm up to extremely low limit
High Tonal Quality Network
In the dividing network, finest elements matching to the unit performance are also used, and by connecting the elements directly to the OFC solidconduction plate which has a power capacity higher than 500 time the normal one, tonal deterioration factors have been eliminated completely.
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2079.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2077.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2074.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2076.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2073.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2071.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2070.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/r_boze0503-img600x450-12594617885mb.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2069.jpg
ALpine DDLinear Satellite Speaker (2 Set)
Model : DLB-200R
Spec : 150watts Max, 30watts RMS
Impedance : 4Ohms
- Suitable for 5.1channel tuning
- Item still in very excellent condition.
- COmplete with bracket!! Don't have to worry any missing bracket!!!
- Very rare item!!
Price : RM500
This picture is taken from Alpine website, just as an example how this satellite will look in yoour car!!
Alpine DDDrive 12inch Woofer
Model : DDW-F30A
Spec : 600watts Max, 200watts RMS
General :
Dual Gap Direct Drive Magnet Design
Neodymium Magnet
Brass Voice Coil Bobbin
2-1/2 Diameter Voice Coil
OFC Edge Wound Voice Coil
One Piece Inverted Dome COne
Hybrid MICA Poly Injected Cone
Push Pull Damper System
Dual Spider Suspension
Diecast Aluminium Magnet Heat Sink
Extended and Vented Pole
Rubber Sorround
Large Gold Plated Screw Terminal
Price : RM800 per woofer
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN1984.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN1981.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN1973.jpg
Alpine Active Subwoofer with Lights!!! Original MAde in Japan!!
Very Rare Item !!!
Spec : 200watts Max Power!!!
Complete Set with socket!!!
Price : RM550
Alpine V12 EXPERT MADE IN JAPAN AMPLIFIER!!!!
DIRECT IMPORT FROM JAPAN!!! VERY NICE FOR SQ TUNING!!!
Model : MRV-F505
Spec :
At 12V 20Hz-20kHz
4 x 50W @ 4 ohms (0.08% THD)
4 x 65W @ 2 ohms (0.3% THD)
2 x 130W @ 4 ohms bridge (0.3% THD)
At 14.4V 20Hz-20kHz
4 x 75W @ 4 ohms (0.08% THD)
4 x 100W @ 2 ohms (0.3% THD)
2 x 200W @ 4 ohms bridge (0.3% THD)
EIAJ MAXPOWER at 14.4V
160WX4CH
400WX2ch
SN : 105db
ORIGINAL MADE IN JAPAN!!!!
PRICE : RM1000
Alpine MRV-F345 4Channel Digital Amp
Direct buy from Japan!!! Complete with original box and manual!!!!
Spec :
# 75 watts RMS x 4 at 4 ohms (85 watts RMS x 4 at 2 ohms)
# 300 watts RMS x 1 (channels 3/4) + 75 watts RMS x 1 (channels 1/2) in bridged mode
# Amp Link allows single cable connection for signal and control with compatible Alpine receivers
# 2-, 3-, or 4-channel output
# Tri-way capable (Tri-Way Crossover required)
# requires 8-gauge power and ground leads
# Bass Engine® features:
* Variable 30-400 Hz high-pass/low-pass digital filters, 12 or 24 dB/octave
* Rear channels have a subsonic filter at 15 Hz
# MOSFET power supply
# STAR Topology (minimizes internal noise and prevents ground interference)
# Speaker- and preamp-level inputs
# Preamp outputs
# Oversized power and ground connections
# Gold-plated screw terminals
# Top mounted controls with cover
# Detachable front cover
# Blue power LED
# 13"W x 2-5/16"H x 8-11/16"D
Price : RM1000
Picture : I will upload soon!!!
Alpine OFC RCA Cable!!!!
Original from Alpine!!!!
Alpine Tuned By Luxman Tweeter !!!! The Legendary Old Skool Tweeter!!!!
This is very limited collection item!!! Very RARE item!!!
Price : RM500
Alpine Phantom Face 7998R Copper Chasis
One of Alpine Flagship Model!!!!
This Unit Original Made In Japan!!!
Best SQ Deck from Alpine
Item still inside my card for buyer to audit.
All in excellent working condition except the screen need servicing
Price : RM1200 (nego)
Picture :
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2418.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2419.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/DSCN2420.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/Image006.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/Image007.jpg
http://i680.photobucket.com/albums/vv170/lazymf83/Image00901.jpg
Alpine DD Linear Tweeter
Price : RM150
Picture :
http://i680.photobucket.com/albums/vv170/lazymf83/DDLinearTweeter1.jpg
*All item has been tested and in superb working condition.
*Strictly for serious buyer only!!
*No SMS or PM as it will not be entertained. Call for faster deal
Serious buyer only to contact Man@012-2398974 (Call Only, No SMS plz!)
*Preferable call me after 6pm as I'm working and may not be able to answer phone all the time
