Alpine 9833 Setup
NavySeals
Dear Sifus,
I need help on my HU's setup. What is the best setup for the X-overs (low, mid & high) and also for the equalizer. Which setup will bring up the vocal, and which will bring up the bass. Please advise. Feel useless having a good set but dunno how to use it. Thanking all in advance.
Don't you have the user manual? Normally that will help you in explaning all the controls on your HU.
Brothers,
It is not that I do not know how to use the system; I know how to go into the setups, but what is the best setup, I dun know. For example :
Low - 0 Phase, 80hz, 18db/oct
Mid - 0 Phase, 100hz, 12db/oct
High- 0 Phase, 125hz, 12db/oct
Is that the best setup? Please advice.
Running on 2 amps, 1 powering front bas mids & rear 3 ways. The other one powering the sub.
are u running active or passive? if passive should set the HU at 2way instead of 3 way.
u're able to change the 2/3way setting, but u need to take out the HU. it is hide underneath the HU.
if active, set the HU at 3 way. then u set the freq according to wht ur speakers can take it. especially the tweeter.
i think it is better to let them know ur items...
if not, they couldn't help u at all.
to bring the bass upfront. i think midwoofer
is the one which help.
my setting is,
2.5khz 12db (high)
between 2khz 18db, 100hz 18db (mid)
80hz 18db (low)
NavySeals said:
Brothers,
i think your crossover only needs to be high & low, or front, rear and sub
to bring out vocals male is around 750hz - 2500hz
female around 1000-3000 hz
for bass would be 50-100 hz
is ther a way of knowing in which mode is the hu in either 2 way or 3 way without actually having to open the hu and check the bottom?
yes... the x-over. if it has bandpass then it is 3 way.
if only 2 way, it will only show u high pass (therefore 2pair of preout
is the same) and low pass (sub only).
