Airtrek Turbo subframe
biao
Hi All Sifu,
i have something need to ask and know about our Airtrek subframe (front) & (rear).
Our front subframe if want to convert to EVO, version 7 to 9 is can fix, right? if only take the EVO lower arm to fix on our original subframe, can?
did any sifu have convert the rear subframe, camber and lower arm to EVO type? if can convert, which version compatible?
I heard from Ah Wah previously that front subframe + steering rod can be installed in Airtrek improving steering response drastically. I am not sure about the rear tho.
front subframe from evo 789 can be fit provide complete with steering rack and driveshaft. rear im not sure as evo has AYC then need to wired the all the electronic system.. if u need LSD, just get the diff internal only and transfer to our rear diff.
if just convert all the arm only without subframe, can?
because i saw the evo arm look more solid than ours airtrek.
