Airtrek Turbo Speed Sensor
Battle.Field
Hi guys,
U do know where is our airtrek turbo speed sensor located? My ODO speed meter aint working. The speed display on my turbo timer aint working as well. So i suspect there is no speed output from the ECU..
---------- Post added at 03:02 PM ---------- 6 hour anti-bump limit - Previous post was at 02:39 PM ----------
Mechanic did diagnostic and confirm that there is no vehicle speed data from ECU..
Hi guys,
If you want to manually check.. it is Pin 80 from your ECU.
Try using a OBD connector and check from OBD too.
Dont think there is no speed output from ECU.. as there are many things depending on the Speed signal for it to be working.
Good Luck!
Thanks for the reply guys.
Yea.. no output from pin 80... OBD diagnostic didnt get any signal too. Borrow another ecu and yeah... its my ECU problem. Sent it for repair and bought myself another ECU for the time being. =D
