air cond prob? any1 can help?
SuperDuper
my new iswara got some sound coming frm d air cond :( , somethng like gas sound,
but cannot smell any strange smell, it only got when i switch on d air cond, when i off it, got no sound...
any1 can help? :lol:
:blink: does it loud? the sound comes while the compressor running?
Hie, proton cars do have this kind of noise where the refrigerant fluid travels through the pipes and created this sound. Even mine also got but not noticeable if you didn't concentrate and listen. :)
For a safer option, check for oil stains under your dashboard , try to look around. :)
Originally posted by ocean+Oct 6 2004, 10:05 -->
QUOTE (ocean @ Oct 6 2004, 10:05 )
--QuoteBegin-SuperDuper
@Oct 6 2004, 00:00
:blink: does it loud? the sound comes while the compressor running? [/b][/quote]
yeah, when d compressor is runnig, d gas sound will come out.. some time very loud sometime not very noticeble.. hope any sifu here can help me out with this :o
well, nv c any stain la, still cant get wat u mean though... :blink:
u mean d fluid travel through d air cond pipe ah?
seem like your new car got many problems le... :blink:
notting to worry about the sound , the gas is been compress and then travels into an expension valve and that is why hear the noise , cause the expension valve its located at the cooling coil , below your dashboard .
Maybe there is an expansion valve where the mechanic can adjust the amount of the gas flow. Might help to reduce some noise, but less cooling efficiency.
hmm. thnk dun wan 2 cut down d cooling effieciency ovr d noisy prob, thnk will just keep it d way it is la! :)
thanks anyway!! :)
