AEM F/IC piggy-back ECU model 30-1910. F/IC for late model vechicles with aftermarket or modified forced induction system. Complete system includes controller module, universal harness, F/IC tuner software CD, USB cable, Bosst hose and bypass plug.
Key Features:
-F/IC tuner sofrware enables real-time tuning adjustability six injector outputs included.
-Uses factory base map to create calibrations.
-Improves drivability and does not affect cold start.
-Works with the latest OBD-ll vechicles including those with variable valve timing control.
-On-board MAP sensor good for 27PSI of boost pressure.
-Supports MAG and Hall type sensors.
More information visit
http://www.aempower.com
Key Features:
