ae86 with a red heart !!!
yolk
[font=Verdana, Arial, Helvetica][font=Verdana, Arial, Helvetica]FRONT Suspension:
T3 coilovers (tokico HTS)
8kg spring
Tein Pillow Ball Camber Plate
T3 Negative Camber Roll center Adjusters
Ueo Style Pillow Ball Tension Rod
Ueo style Lower control arm
REAR Suspenion:
T3 Coilovers (tokico HTS)
6kg spring
Cusco Upper Formula Links
Cusco Lower Formula Links
Cusco Lateral Rod
Brakes:
FRONT :
T3 300mm Big brake kit
Willwood calipers and pads, Precision brake co. Rotors Stainless lines
Rear:
Brembo Cross Drilled Rotor Cryo Treaded by Porterfiled Enterprises Stainless Lines Porterfiled R-4 Full Race Compound Pads
Steering:
True Manuel rack
True Manuel column
Power knuckles
Drivetrain:
Transmission: 2002 6-speed Honda S2000
Custom Propeller Shaft
Cusco RS 2 Way LSD
Motor/Power:
2002 Honda AP1 (S2000)
AEM Engine Management system
HKS Exhaust
Custom Intake By Evolution Motor sports
Custom Large Volume Aluminum Radiator , Two 10" pusher fans w/Thermostat starter
Instrumentation:
2002 Honda S2000 Digital Gauge Cluster
Greddy 60mm oil temp
Greddy 60mm water temp
Body:
J-Blood Wide Front Fenders
J-Blood FRP Doors
J-Blood FRP rear Over Fenders
J-Blood FRP hatch
J-Blood C/F Drop Vent Hood
J-Blood Rear Wing
Toyota sprinter Tails
Toyota Kouki Bumpers
Toyota Zenki Front Lip
Fuel System:
ATL 8gal Racing Cell
ATL "Black Box" Surge Tank
Walbro fuel pump
Custom Install By Full Function
Chassis / Reinforcement:
Full Function 8 point cage
Stitched Welded Seams
Additional Spot Welds on Door Frame and Rear Quarter Window Frames
Wheels/ Tires:
15" Work equip 01
yokohama es100
Interior:
Sparco sprint seat
T3 75mm hub extender
Nardi 350mm steering wheel
http://img.photobucket.com/albums/v235/senmugen/Picture044.jpg
http://img.photobucket.com/albums/v235/senmugen/Picture042.jpg
http://img.photobucket.com/albums/v235/senmugen/red86002.jpg
http://img.photobucket.com/albums/v235/senmugen/red86001.jpg
http://img.photobucket.com/albums/v235/senmugen/sneekpeek.jpg
http://img.photobucket.com/albums/v235/senmugen/factory019SMALL.jpg
http://img.photobucket.com/albums/v235/senmugen/factory010SMALL.jpg
http://img.photobucket.com/albums/v235/senmugen/f20work003small.jpg
http://img.photobucket.com/albums/v235/senmugen/factory033SMALL.jpg
http://img.photobucket.com/albums/v235/senmugen/f20work008small.jpg
http://img.photobucket.com/albums/v235/senmugen/f20work007small.jpg
http://img.photobucket.com/albums/v235/senmugen/f20work029small.jpg
http://img.photobucket.com/albums/v235/senmugen/f20work032small.jpg
http://img.photobucket.com/albums/v235/senmugen/pics010small.jpg
http://img.photobucket.com/albums/v235/senmugen/pics004small.jpg
http://img.photobucket.com/albums/v235/senmugen/pics003small.jpg
http://img.photobucket.com/albums/v234/dullie143/ae8658.jpg
http://www.fftec.com/media/content_images/Dyno_Day/P8260002.JPG
http://img.photobucket.com/albums/v234/dullie143/ae8651.jpg
http://img.photobucket.com/albums/v234/dullie143/ae8655.jpg
http://img.photobucket.com/albums/v234/dullie143/ae8630.jpg
http://img.photobucket.com/albums/v234/dullie143/ae8637.jpg
http://img.photobucket.com/albums/v234/dullie143/ae8649.jpg
http://img.photobucket.com/albums/v234/dullie143/ae866.jpg
[/font]
[/font]
nice choice of engine swap, hahahhaa
as far i as i know the s2000 engine is the higher power to cc ratio engine. "falali" also kalah
but i wanna know what he did with the rear suspension, he got the L shaped plate welded on it n with something stickin out......
anyone got any idea?
chek... i think its for the roll cage.. issit? .. woah VTEC worr, issit F20C? ... damn!
but they spoilt the toyotas tradition by mix marriage like this, toyota have much more powerful engines, why dont he try blacktops or supra's .. ;)
Waahhh! Another one of those rare monsters. I bet Yolk have much more sleepless nights liao. hahaha
Sakuraguy, well we can say mismarriages bring forth monsters. hahaha. Anyway From my observation, AE, KE & TE platform can take in a variety of engines. So far we have seen many 4 cylinder engines like, 3SGE from altezza, some hybrid 3S-GTE, CA18 & SR20-DET from Nissans, 13B & 20B from mazda, 4AGE 20V & F20C from Honda. 6 cylinder engines like RB 1G and 2J are very rare for corolla platform. Because it involves many cutting and modification. True drivers might complain the handling is way off using 6 cylinder engines. Now i have yet to see and Evo and Scooby engines inside corollas. hehehe.
Man i really dig the steering assembly setup. For drifting sure dam kaw responsive and quick wan.
