AE86 + engine stuff for sale
SL_77
Got a couple of AE86 stuff for sale:
A) Levin rear tail lights set. Condition 9.5/10. Virtualy scratchless and looks new. SGD$270.
B) Levin meter. Good condition except odometer is jammed on the 2nd digit. You can see it in the picture. SGD$130
C) *Brand new* KYB AGX short stroke shocks comes with new gland nuts. Front and rear adjustable damping. These are not your typical run-of-the-mill standard long stroke shocks. SGD$750 for just the shocks or SGD$1200 including front coil-overs with Cusco camber plates and Revolver Sports 8KG springs /w assisted springs and rear TRD 6.5KG springs.
D) AE86 doors (1 pair) - SGD$250
E) T50 bell housing - SGD$100
F) AE86 stock front calipers - SGD$80
G) AE101 Levin stock front calipers & rotors - SGD$150
H) Faulty Turbonetics ball-bearing T3/T4 turbo (fins and shaft in good condition but dunno why not holding smooth boost between 0.5 to 0.7bar boost) - SGD$150
I) Stock castor rods with PU bushing - SGD$80
J) Stock GZE 8.9CR pistons - SGD$150
K) Stock GZE con-rods - SGD$180
L) Stock GZE camshaft - SGD$80
M) Stock GZE valves + springs - SGD$150
N) AE86 4.33 rear diff (Non-LSD) - SGD$150
O) AE86 Levin bumper - SGD$140
Items location is in Singapore. All items are in good condition unless stated otherwise. Willing to ship at your expense or you can do a local pick-up in SG or JB.
Interested, drop me a PM. Or if you need any spare stock stuff from a GZE engine (Rods, pistons, valves, etc...) coz rebuilding engine with aftermarket parts.
Thanks.
johntoh said:
hi, is your piston the low com type. is the price for 4
Yup, it's the AE101 4A-GZE ceramic-coated top low compression pistons. 8.9CR compression ratio. Price quoted is for 1 set of the pistons including the rings and pins.
Cheers.
johntoh said:
where can i see the piston? can it fit in 20v bt?
Nope, you can't fit it to a 20v BT engine without making some modification to the piston for the 5th valve clearance as the GZE is only a 4 valve head originally.
It's something I wouldn't recommend as cutting a clearance for the 5th valve would only destroy the ceramic coated top of the piston hence making the piston even weaker than your original 20v pistons due to the imbalance of heat spots after the modification.
