Advise on Perdana V6 headlight
gotdamsg
Hello all, I am looking for professional advise regarding my PV6 headlight. As we all know the current one is not that bright, very dim and not so good especially when in high speed. How do I change or upgrade it to a brighter + can see longer distance + yellowish white color + non glaring (I dont want to hurt other drivers). I will have no problem spend much on the headlight as safety is the first.
I am not quite expert on this so I would expect professional feedback and comments from professionals here :)
some ppl said I need to install relay kit? do I need to do this for the Osram nightbreakers?
---------- Post added at 12:17 PM ---------- 6 hour anti-bump limit - Previous post was at 12:14 PM ----------
and what is H1, H4 and H7?
im not sure, or u could install a booster kit....eneos or brothers sells it,
u could try 1st, if still dimm then get the booster kits......
h1,h4,h7 is the bulb sizes, most cars are using h4, perdana is h4. waja using h1 if not mistaken somthing like that.
