Is it advice to re-paint the evo hood vent ?
The paint start to fade, and I thinking to DIY it, anyone do it before?
Any paint peeling after sometime(heat) ?
1- remove d vents (if it's removable) or if x just mask tape accordingly
2- wet (soap) sand it using 800-grit then 1500-grit sandpaper
3- spray on plastic primer (if u have) or
4- just spray d required color...thin 1st coat n let dry for 10mins..then proceed wiz 2nd n subsequent coats...3 coats wld be sufficient..
Hope this helps...happy diy-ing
Oh ya another thing I only use samurai brand can spray paint as it's d closest to automotive paint...
