Accord SV4 wiper problem
Tony Yeap
Hi, Guys,
Need advice from sifu,
Recently my 96 Accord SV4 had wiper problem. when I switch on the intermittent stage, the wiper swept non stop. As for the slow and fast speed , it works okay.
Sometimes when I switched on the wiper at intermittent it swept for a while and stopped. At times it swept non stop. I have to pull my car at the road side and off the engine and start again. Sometimes it can be off and at times it will repeat sweeping non stop.
I've tried to replace the wiper stalk switch which comes together with the light stalk but it's still gave the problem.
Then I tried to replace the wiper relay which is like a white box, but the problem is still unsolved.
Now , I'll try by this weekend to send the car to check the wiper motor wiring.
Hope it will solve. Any suggestion or advice to rectify this problem
Thank you in advance.
Regards.
I've solved my wiper problem by replacing the wiper sensor relay beneath the bonnet fuse box which is blue in color c/w black cover. The white box relay which I mentioned early was for the door winding mirrors.
