Accord CL9
muhammed,
i just got my eibach pro-kit lowering springs from a friend of mine, a used one. So i guess won't go to klang anymore. However, the lowest price i checked so far is from x-tune, they offer me as low as RM950 for this kit, but need to order 1st which will take 4 maximum 4 weeks time. Go to this website X-Tune.com, contact Zack or his associate and they will get it for you.
Ok Awesome , I'm glad you got Sorted , Were those the Same Springs off the CL7 Euro R ? If they are I believe Azril is replacing with Tein , Maybe he could give a Good comparison Between Eibach and Tein , Both are Great Springs , Did he mention Why he decided to replace his Eibach with Tein , Would be Interested to know Why
what??
you guys TT never call2
I was in KL this past weekend.
opppssss....hohoho, don't mad at me :rolleyes:...ask spiderman, he's the tok penghulu...hahahaha!
azril, seems that u need to respond, muhammed also seek ur opinion on spring thingy in his previous post.
U cannot compare between eibach and tein,eibach is just a coil spring 4 lowering and comfort,tein is a full-length ride height adjustable shock absorber .
Correct me if im wrong..
Ok so you are Upgrading from Just Using a Lowiring Spring to A Adjustable Spring and Damper kit , What would a Kit like that Cost , and The Place you are buying them At , Do they Stock Tein Lowering Springs , Tein do make Lowering springs too , that are Similar to Eibach , But not Sure on the Cost
hi fellas....
my K24A engine still got the speed limiter. Actually, plan to use Pivot Speed Meter V to remove the limiter function but unfortunately it's not compatible for K24A, it could be installed for other function except for Speed Limiter Remover....aiiyyooohhhhh :banghead:.
Got any idea how arrr??? Cruising a 2.4 engine on a freeway with maximum speed 180kph is really2 unacceptable u know...hehehehe!!
Yeap....HKS SLD Type 1 but still trying to locate the dealer. Checked with JRacing, N1 they got no stock, Kakimoto still checking. Where else meh??
Another thing, if use HKS SLD...meaning that I still need to add additional speedometer aite? Or could it be connected to Pivot Speed Meter??
Or you can get a Good tuner , and a piggyback Chip , like Dastek UniQ , Or any Other and have no Limiter as well as Much more Leeway to extract Power from that K24 by Fine Tuning
have u done it muhammed?? if yes, how much it will cost me, and where??
I have not Done it , But have friends Some , Have Used Piggybacks , and Some Standalone Management , They Did Manage to extract more power from the K series , In Malaysia However , Dastek UniQ is available , But who stocks it and where to Tune it , that I cannot Answer at Present , But I am Pretty sure Someone on the Honda Forum can give some Guidelines
guys.....
i've checked already, got two option on how to remove the limiter for the K24A;
1. RSM - by right, the diagram didn't mentioned that the RSM could function well on K24A, however KakiMoto & JC Racing claimed that they've done it before, they know how to manipulate and configure the RSM to work for the engine.
2. HKS SLD + Pivot Speed Meter - HKS SLD clearly mentioned it will function well with the engine, however since the SLD doesn't provide speed indicator, it require connection to Pivot.
The cost for both method is about the same, it just that option 1 is a self configuration by the mechanics and the option 2 is a factory setting.
Any opinion?? :smokin:
I had a chat with Tony from SHC ( I think his name is Tony, since he has an SHC sticker with the name Tony)
We were chatting at Ah meng's tyre shop, and he said that the best method to remove the limiter for the K-series is by using Pivot Speed Meter. he didnt mention about using HKS's speed limit defeater though. just the Pivot Speed Meter. a much cheaper option compared to Apexi's device.
He drives a CL9 TypeS (with TypeS badge at the rear) which I suspect is an Aussie model, since the car doesnt have HID.
bien,
i wish u could find out more from this guy tony. I've checked with 3 major places at Sunway, the Pivot Speed Meter won't do for K24A. It's definitely cheaper but since nobody could give any warranty on that, i'm rather not doing it.
thanks anyway...
