ABS light on when VTEC open
EK9wanabe
Hi there ZTH
Anyone outhere has a wiring diagram and know how to connect the ABS light in meter cluster to the ECU.?(no ABS ) B16A in EJ96 body....Heard that this kind modification famous in US...The purpose is to see ABS light on when VTEC engage....
TQ for any reply....
Hi there ZTH
Vtec Light? This is quite simple, actually.. instead of connecting it to your ABS indicator, you can simply use any one of the vacant spaces on your instrument panel. wire up a simple LED, negative to ground, and positive to the live wire on your vtec solenoid (or ecu, whichever u prefer). there are tonnes of sites which has write-ups on this..do your research first..
For example, look here : http://www.hondacivicforum.com/m_248922/tm.htm
Have fun, and good luck.
