About CPS engine.
iLachva
I heard from my friend that this CPS engine are from japan's or somewhere else 2nd hand campro engines. and msia just renew it and use for campro engine in satria neo cps and all the cps type.
Is it true? correct me if im wrong. Wanted to make sure.
And for performance, which local car is the best for it?
Satria Neo CPS? or Satria neo? or gen2..etc
its from malaysia. well parts of it. by the design and parts, i dont think its an engine produce by another car marker since it doesn't have a common spare parts with other make. from my knowledge, the cps engine will have further upgrade for the block and the variable valve. if your not in a rush. i suggest that you wait for the upcoming engine model
heard you cant rebore the block?? use bigger pistons...
a much better engine then the campro kosong though..
