About Boost Meter
playaz7
HEY People!! I've installed a Boost meter in my car...
Ya'll know that Boost meter, the 0 is in the middle then the vacum is down and psi is above the 0 rite?
Y my meter, it only can go a lil b4 0 oni?? cannot go above 0?? I mean it cannot go to PSI la...
What does Psi stands for??
Can anyone help me out bout my problem??
Thank You!
u need VACUUM meter not BOOST meter
cant go up 0 coz ur car no turbo...so turbo meter cant function
u geting the wrong meter for ur car....
NA car need vacuum meter.....Turbo car need boost meter
Thank You!
to make it function...there is only 2 choices for u
1st is to chage ur boost meter to vacuum meter
2nd is change to turbo engine or bolt-on turbo kits...then u wil see how boost meter works..
cheers....
wuahahahahaha.... luckily huakenny sifu teaches u o... so next time remember lo..
cheers ! n happy modi..
u must b new wit cars.... ahahhaah :wink: bolt on mean plug n play... no turbo make it to turbo.. that means ur standard engine just bolt turbo on it.. use original engine... thats all... other option just change to turbo only...
i personaly not sugest u to bolt-on...1st ur engine is carb n old oledi
change to a efi na engine la...turbo engine for u is not suitable...u stil new
playaz7: sound system damn expensive to play wor..play performance better, spend bit by bit. to me sound system gota spend damn alot if ur looking for high end. need this to support that, need that to run this. things like dat..fuh..summore damn scary ppl smash mirror to steal ICE. anyay blow-off only meant for turbo, seems ppl saying ur driving NA, it is impossible for the needle to reach boost. anyway happy boosting nextime ya.
hy seefus..
some quest..?
if i drive turbo car to balik kg (drive about 400km)..
how 2 maintaince boost (meter reading)
hope all turbo owner can help me...
tq..
speedy_05 said:
hy seefus..
some quest..?
tq..
dun owes full throttle.....
if i drive 150-160km/h on 5th gear...0 bar....so wil go up to high bar when overtake car only....
try to drive carefully n safely.....dun show ur boost....got speed trap some more...heheh.....
wah.. din expect so many patient n kind replies la... tot u all going to laugh at playaz7 or call him beng ady buy boost meter but no turbo.. but then so many good response... respect la to u all!! :smile:
dun laugh people la...we learn from each other ma....
im oso in learning stage..hehehe...many sifus here la... :tee:
Bro Playaz,
U can also play sound wann..just install 'kachingg' BOV sound (electronic one,i think around rm200 only) to your N/A car, so u will boost like a turbo car...kachinggg..kachjinggg...
