A32 Cefiro ECU pin-out diagram wanted!!
as i did the matching between the maxima's ECU coding and the Asian version A32 ECU's coding before posting, it is all the same..... except there is some pin is not usable in Asian version....
---------- Post added at 04:05 PM ---------- 6 hour anti-bump limit - Previous post was at 04:02 PM ----------
Weikee, infiniti I30 share the same coding only with our ECU, but the location of the pin is totally different, also the plug shape and layout is totally different...
---------- Post added at 04:09 PM ---------- 6 hour anti-bump limit - Previous post was at 04:05 PM ----------
for example, Pin number 1, 2 3, 7, 8 and 9 in both manual ( US and Asian version) also stated as ignition signal 1 - 6 respectively.... the harness colour coding is totally the same.... hence i think the only difference between US and Asian version is only the layout....
---------- Post added at 04:12 PM ---------- 6 hour anti-bump limit - Previous post was at 04:09 PM ----------
this is the ECU pin out
Bro almeshtaq, this is the same as what u said u like my 1st post ( the attachment in post number 16), this is the croped version so that u can see the pin code clearly lar.... check with your ECU n u get same numbers of pins and location.... Also, infiniti manual totally doesnt have this flat pins ECU diagram lar...
ــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــ
How can be the same number of pins and location if Cefiro has only pin 1-116 and Maxima & Infiniti have more than 116 ??? look at the Two different ECU below!!
UC, not sure we are in same channel, anyway the ECU in A32 have more pins, same goes to all newer Nissan ecu. I use Maxima ecu pin out to find some of the signal in my cefiro, is not 100% match, some i got to trace back (i mention this too earlier in this post).
almeshtaq, in the web you maybe able to search some forum someone did a e-managed installation to A32 and A33, it give you all the ecu pin layout that may help. But then again each year nissan may have some slight change of pin layout. you still need to retrace it back.
almeshtaq, in the web you maybe able to search some forum someone did a e-managed installation to A32 and A33, it give you all the ecu pin layout that may help. But then again each year nissan may have some slight change of pin layout. you still need to retrace it back.[/QUOTE]
ــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــ
As I said before I have spent "one" year looking for this through internet!!!, also I did search e-manage installation to A32 ,but found only installtion to A32 Maxima&Infiniti :adore:
please check both diagram shows different plug type for both ECU you shown to us.... as u can see from the different page numbers, EC-72, EC- 252, I took them from different manual...... i dunno whether i might help you but this is what i can offer.....
please match both diagram with both your attached ECU pin out before you come back to me.... Also, attached is the Asian version ECU coding, u might ask somebody to match it for you, but as far as i checked last time, it is all the same.....
1stly bro almeshtaq, i didnt claim that Asia ECU have 124 pins.... they have pins up to no. 124 but there are some missing pins in Asian ECU..... Also,A SAME THING BETWEEN BOTH ECUs IS THERE IS NO CODES FROM NUMBER 81 - 100.... thus, eventhough US version has 116 pins in total (as u stated), there is a pin coded no. 124....
After my calculation.... the asian ECU (the blue one in your attachment) has 84 pins, total of four sections,
1st sec - from pin no. 101 to 116 -16 pins
2nd sec - from pin no. 1 to 20 - 20 pins
3rd sec - from pin no. 21 to 40 -20 pins
4th sec - from pin no. 41 to 60 -20 pins.
missing pins in Asia A32 ECU - no pins for 61 to 100
US version has 116 pins (the 116 pins that u stated) (As attached in your picture which was hold with hand) , divided into 8 sections ....
1st & 2nd section - from pin no. 101 to 124 (horizontally) - 25 pins
3rd & 4th section - from pin no. 1 to 19 (horizontally) - 20 pins
5th & 6th section - from pin no. 20 to 43 (horizontally) - 24 pins
7th & 8th section - from pin no. 44 to 80 (horizontally) - 47 pins
no pins missing in US A32 ECU
---------- Post added at 02:39 AM ---------- 6 hour anti-bump limit - Previous post was at 02:26 AM ----------
Bro almeshtaq..... please check the quote above that i hi-lighted with colours .....
the 1st quote in green -maxima's ECU coding and the Asian version A32 ECU's coding before posting, it is all the same..... except there is some pin is not usable in Asian version....
from the quote above, i already told you that both Asian and US ECUs share the same pin number codings, except a few codes is not usable in Asian version (means the Asian ECU does not have these pins), thus, i did not state that Asian version has 124 pins. IT IS NUMBER CODINGS, NOT NUMBERS OF PINS.
the 2nd quote in red -nfiniti I30 share the same coding only with our ECU, but the location of the pin is totally different, also the plug shape and layout is totally different... harness colour coding is totally the same
From the quote above, i already told different pins location between US and Asian version A32 ECU... the same is only they share the same number and wire colour codes.
the 3rd quote in pink -this is the same as what u said u like my 1st post ( the attachment in post number 16), this is the croped version so that u can see the pin code clearly lar.... check with your ECU n u get same numbers of pins and location.
From the quote above, what i mean is the 2nd ECU diagram attachment that i posted is the crop version (means enlarged) diagram of the 1st ECU diagram i posted ( when i posted the 1st ECU diagram, the whole page version, if you click and check, the page will be very small and become blur if you zoom in (u would get rough pixels)), thats y i send my apology as "TOO ROUGH TO VIEW"!! and i repost on the second day.... thus it is from the same page.... if you match the enlarged attachment u might see the codes clearly and is matching our Asian A32's ECU.... thus it is the same numbers of pins and location between the enlarged diagram ( the one i written "Engine ECU Diagram for "WY") and your A32's ECU....
---------- Post added at 02:58 AM ---------- 6 hour anti-bump limit - Previous post was at 02:39 AM ----------
Bro almeshtaq, please stay calm and check whatever i said before you make a statement..... I had spend day and night trying to solve your problem without any benefit...... I might just leave my keyboard from this thread, but im still staying here and trying to help. Thus, even if i had make a mistake, you might point it out for me.... the quote above is really a distracting one, I hope you understand..... tq....
---------- Post added at 03:06 AM ---------- 6 hour anti-bump limit - Previous post was at 02:58 AM ----------
Also, I didnt upload the Asian pin number and colour coding lists yesterday coz too busy, will upload this afternoon... my apology...
---------- Post added at 03:22 AM ---------- 6 hour anti-bump limit - Previous post was at 03:06 AM ----------
yeap u get what i mean, the Infiniti !30 or Maxima ECU has more pins (116 pins) compare to our Asian version so-called flat-layout ECU ( 84 pins). I had stated that the wire number and colour codings seems to be the same...... i will upload the Taiwan version of ECU coding lists this afternoon (in the same manual which i uploaded my ECU diagram pic stated "Engine ECU Diagram for "WY"), the "WY" is marked on our ECU as shown by you..... but i cannot guarantee that the Taiwan version ECU will have the exact pins coding and location with our ECU although both also has the same pins layout..... but as i seen in the net, the taiwan version of A32 engine is the same like ours (which has a big intake body, so-called MEVI i think) and not the USim version ( which has 6 intake pipes instead of body)..... so i just ASSUMED it to be the same
UC, my ecu is the newer version (with more pins). Even the 1/2 cut i got from japan is also using the newer ecu.
Weikee, if u can show me the picture of the ECU then it would be better..... but what i attached is to match Almeshtaq's attached ECUs, so it might be different from yours..... u can match both my diagrams ( "WY" version and US versiondiagrams) with both ECUs picture that he shows..... as he said, he HAS the "WY" version ECU (so that is the earlier version A32).... Also, the title for my Asian version Cefiro manual is for A32 from yr 95 - 98, for VQ 20 and VQ 30..... since i dunno what year your halfcut is, also dunno VQ what.... so i might not know whether they have any differences.... so spare me.... thanks.... but at least i have to fulfill almeshtaq's enquiry....
attached is the Asian ECU Harness Colour and ECU Pins Coding Lists...... for A32 VQ 20 and VQ30 FROM YR 95 - 98.....(please, i dunno whether it match JDM VQ25, or A32 earlier than yr 95 or later than 98, it is stated there 95 - 98 A32 for VQ 20 AND VQ 30, so you all might check it yourselves) pls check.....
help needed, anyone has vq25de ecu pinout diagram ?
my halfcut vq25de (jdm spec) has ecm (engine control) and tcm (auto transmission) in one ecu. Local malaysia ecm (engine control) and tcm (auto transmission) are seperate unit.
Really need help on vq25de ecu pin-out diagram (for ecm and tcm in on ecu)
put everything from h/cut to ur car... hassle free :driver:
Hello...anybody can help me? I have a cefiro 2.5 ...but very nt save fuel ..rm100petro only drive 400 km ...I drive very smooth...and I also below 2500rpm..I heard other 2.5 can reach 500km to 600++km...I change pugs, engine oil, air filter....and anything need to chage ?
