A Small Problem With My Wira .. - HELP
sakuraguy
5,000 RPM
I didnt ride my car for 2 days because of some business busy-ness. Today I started and drove to town and i took a full U-Turn out to mainroad .. "GGGRRREEEEEEKGGRRR" .. sound .. I tought because halted for 2days and squeezing sound.
Again turn got sound .. this time not full U-Turn, light turn and my car seems vibrating on the left (passanger side).
Got back home and checked engine bay, but seems okay .. unfortunately i opened my power steering bottle .. yiaksss! .. the oil missing leh!
Why? ... anyone knows? I filled up the oil but missing also again .. :confused_smile:
Got some stain on the drive shaft!...
My question:
1. Can get 2nd hand unit of the item if wanna change?
2. Cost of repair ?
3. Any good shops near Srimuda, Shah Alam area?
Pls.. pls.. my dearest car is sick now i think!
Thnx guys!
:confused_smile:
My question:
2. Cost of repair ?
Thnx guys!
i think is ur power steering pump or rack got problem, not relate to drive shaft, better check it out:X-:
or myb sum power steering related seal broken.... sum power steering oil got prevent leak 1~ but it will not help if da seal broken serious
my dad put wrong fluid gear oil to power steering fluid....got the GGGRRRRRNNNGGGG sound when u steer the steering without moving the car
better go to workshop, n use machine flush n replace the correct fluid insidem, or else its will harm ur power stering seal n cause leaking, if serious may cause ur power steeing malfunction also.
