D dev Known Member Senior Member Nov 13, 2005 #1 i want to install a A/F Ratio Meter.. i want to know which wiring should i look 4 to tap the signal... im kind of blur wit wiring 4 A/F meter.. never installed 1 b4... thanx
J japle Known Member Senior Member Nov 14, 2005 #2 i also want! where did u buy this afr meter? how much is it? i also 1 2 buy, cuz i suspect something is wrong with the ratio...:(
D dev Known Member Senior Member Nov 14, 2005 #3 havent bought it yet, bro... planning to buy n install it.... =) u can buy it as KSP, N1 o any performance shop near ur place...
huakenny LB Performance Senior Member Nov 14, 2005 #4 wat brand? 3 wires or 4 wires? mine is 4wire....black = ground, red= ignition, blue = light, green = ecu o2 if not mistaken... juz wanna know which to tap to ecu then ok..
D dev Known Member Senior Member Nov 14, 2005 #5 Auto Meter bro... im not sure how many wires... Last edited: Nov 14, 2005
huakenny LB Performance Senior Member Nov 14, 2005 #6 dev said: Auto Meter bro... Click to expand... wat car to instal? i might hv the diagram..im using autometer as well... but the file too big..i cant upload here...find me in [email protected] msn messenger i send to u..
D dev Known Member Senior Member Nov 14, 2005 #7 i been trying high n low to find my ECU wiring diagram... B20B on accord body not prelude.... ur help is appreciated bro... thanx Last edited: Nov 14, 2005
huakenny LB Performance Senior Member Nov 14, 2005 #8 dev said: i been trying high n low to find my ECU wiring diagram... B20B on accord body not prelude.... ur help is appreciated bro... Click to expand... ecu is folow ur engine la...car model not important..engine model only i got tat diagram...but B20B got few model find me in msn messenger..i send to u the diagram...u see which one la...ok? got ecu diagram for u...easy only
