'91 lancer engine problem
Hello.
I have a '91 lancer 4wd wagon. The car is great, but i have some problems with my engine and i dont know what is causing it. The problem is that when the motor is cold it has problems starting up. When you try a couple of times it runs, and when the motor heats up it runs perfectly. I am worrying that in winter when it is colder, it might not start up. Engine is 1.8l 4g37. If anyone could help me i would appreciate it.
4G37??? Or 4G67 maybe? It's 1.8ltr DOHC right? If 4G67 then I used to have the same very long time ago.
Anyway for your problem, try servicing the starter motor. Adding a relay like the one normally used to make lights brighter might also help a bit.
