4G94 Mivec
qme9019
Calling for all mivec sifu , anyone here hybrid their Mivec 92 to 4g94 ? if do how does the result? can produce 200hp ? how about $$ and any other information i'm planning to do this for drag racing.
200hp , but from mivec forum nz i do see some of them said this 4g94 is not suitable for high rev ? what do you think about this ?
please i need more advice from mivec sifu
200whp easy with a mivec 4g93 with jun2 plus 4 throttle. Dont envy those aussie cause previously I have the highest hp compared to them aussie. You can check with them for conformation.
proud to be malaysian.
Currently my car is running on 4G93 Mivec but i don't understand everytime my mivec kick in it will lag , and last time my car are not really tune by pro.
Now after tune are better . but i am willing to trying to make it 2.0 with 4G94 since now my mechanic are very confident he can make it .
but from what i read from mivec nz 4g94 is not good for high rev due to 6500 max rpm.
my question is does anyone here at malaysia do produce are succesful 4g94 mivec? if yes how was the performance?
i'm already in 4G93 Mivec .
Whats the point of building 4g94 mivec when 4g93 engine havent reach its maximum potential ? The difference between great 4g93 and the normal 4g93 depends on hp they achieved.
Until now I havent see 4g93 that reach my HP which is 208whp without race fuel. PPL talk about
4g94 but the dont realised the downside that engine have,,,extra long stroke means low revving and unsuitable for race cam that markets have.
Thank you for your precious reply (nutter)
IF i intend to build 4G94 Mivec what do you advice ?
4G93 to the limit around 200HP or little bit more .
4G94 to the limit no idea will be success or not , and how much spend is still a question but i'm willing to give it a try and this project seem to be interesting maybe i'm stupid to you .
so your 4G93 Mivec 0-400 what time ? very interested and hope you can help to answer my question
i'm really wish to build it to fight with Vtec on coming Borneo Drag event.
On 2004 SDB Sepang i managed to clocked 12.4 with a broken gear. I dont recommend 4g94 bcoz xtra stroke it have. I held the record for 5 years until been beaten by my fellow fren with a record of 12.2.
WOw that's good time . clocked 12.4 on what car? Satria is it ?
very sad to heard that from you 4g94 are not suitable.
---------- Post added at 10:53 PM ---------- 6 hour anti-bump limit - Previous post was at 10:52 PM ----------
yes a satria,,,you can browse you tube and look for it. search mivec melaka or mivec oren.
ok bro appreciate for your help. i will try to find more information about 4g93 mivec convert to 4g94 .
i just watch the clip you post at youtube!
Bro how much jun stage 2 cam you get? and are you using lsd ?
alright .
Bro so your advice is push my mivec93 to the limit and see what hp can produce rather than try 4g94?
but i wish it will also suitable for daily use , possible ?
qme..well...if u have any plan to install high cam later on i suggest u not to use 4g94.....
but if u plan to keep it stock and only fine tuning the ECU-stock camshaft function and daily ride then u can go for it...but don't expect that it can rev higher than your current setup and reliable at the same time........or else u might risk to premature failure of crank bearing/conrod itself....
thats my opinion :adore:
may i know how high standard bottom 4g93 can safely rev without balanced engine and forged internal?tq
Wonder if anyone of you modded the mivec terbalik (transverse engine on CK4A/CJ4A/coltR) engine.
I rode and owned a stock Lancer CK manual tranny for few years & it has lots of potential..
Gear Ratio much better than B16A EK4
alright thank you for your precious opinion !
but i will push all teh way to the limit for this convertion
---------- Post added at 12:16 PM ---------- 6 hour anti-bump limit - Previous post was at 12:12 PM ----------
sorry forget to mention i'm doing this to terbalik engine. CK4 for Waja
