4G93T ECU help
does anyone no where i can get a ECU for this motor or if i cn use the ECU from a 4g63t with it i know the wiring is different and thats my other problem i need the wiring diagram and pin outs for both of these also if anyone has a 4G93T ecu i will buy it if the price is reasonable
advise here~~!
hi,ah beh here....
wat the diff between 93t and 63t ecu....if plug and play
first,if u use 63t ecu in ur engine,u need to add FITC in ur engine cause it will adjust the air cond ideling....63t FITC i/c diff with 93t
then,u hav to change the air flow sensor if u using 63t ecu
wat i wanna tell u here is ,if u using 63t ecu,it will more cost than u buy a 93t ecu...93t ecu is cheaper than 63t
wat good and benifit of 63t ecu is it can be chip
i hav 93t ecu.....7377 right?
u think clearly la....
call me if u wan it...
ah beh 016-6000682
office 03-41430920
see u
