4g93 sparkplug cables connection sequence?
trex92
Does anyone knows the connection sequence of the spark plug cables for a 4G93 engine? From the distributor (vertical row of 4) to which cyclinder?
Distributor
A
B
C
D
Cyclinder
1 2 3 4
anyone can help (A connect to??, B Connect to ?? etc)? THanks... :)
In my case, there is a label at the distributor which shows 4,1,2,3 from top to down. According to my mechanic, that should correspond to each cylinder where the one nearest to the timing belt is cylinder #1.
so i guess in your case the combination would be:
A-1
B-4
C-3
D-2
Correct me if that is wrong.
Distributor
A
B
C
D
Cyclinder
1 2 3 4
A-1
B-4
C-3
D-2
wow.. thanks man... urs got a label...? Located where? Mine's a Putra and I could not find a label... I took our my spark plug cables once then forgot which sequence. So just want to double check whether i plugged it properly or not.. many thanks :)
I dont know about putra but mine is 4G93 oso. there's a sequence label at the distributor where u plug the other end of your plug cables. You might want to to wipe the shining metal part a bit (nearest to the intake manifold) and try to see if it's there.
shining part? Hmmm, but the distributor part in my car is all black in colour wan, but anyway, i would try to look and see whether any labels around that area.
