4g93 head - RM350nego ..
CSx8213x
Wanna let go a 4G93 head ...
head only without inlet manifold and throttle body ....
everything inside a head still available ....
include cam , tapet, valve , valve spring ... and the cover ...
Can plug and play for 4G91 and 4G92...
RM350 nego ..... SOLD
Contact : 016-2788213
4G91 (1.5 sohc) with 4G93 head = 1.8 DOhc (more power)
then
4G92 (1.6 sohc) with 4G93 head = 1.8 Dohc (super more power)
oh.. like this ah.. it means if got a 493 and fit with 4G63 head oso more more POWDERFUL la..
hahahaha.. waah.. mana workshop ajar itu macam ah? itu macam pun boleh ka..
4G91/4G92/4G93 all have the same head with the same port size, no differences.
Whahaha, no hard feeling but if you read the manual of the 4G9X
All the size from 4G91 to 4G93 is different lah.
even sohc and dohc engine will give you different power. for example
4G92 sohc = so powerful
4G92 dohc = so more powerful
BTW 4G93 can't fix in a 4G63 head (as far as i know) coz is totally different.
how can all the head be same size ??
4g91 = 1.5 , piston small
4g92 = 1.6 , piston big
4g93 = 1.8 , piston bigger, inlet & exhaust also larger
Dun believe, go measure the 3 heads to confirm
softmuffin said:
yes yes yes what ramsink say is very true.
but ramsink don't fire the guy already. kasihan dia
not i wanna fire that guy, just tak boleh tahan he fire ppl with the wrong facts 1st
Yeah yeah yeah, you're right.
Bcoz of this kind of ppl who give wrong info make others ppl who are trying to mod his/she car more faster scare. worst come to worst parts or idea which is able to give the car more power is wasted bcoz nobody dare to try..
so guys,if i put this head on my 4g91(DOCH)...it would be 1.8 laa rite???pls confirm with me and wat are the things that i need to consider???
aiya..
tu pun mau gado² ka..
if u r using 1.5sohc..yes u can use 4g93 head...
but da cc is still da same..still 1.5...just it will become to 1.5doch.. :D NO NEED TO REGISTER :)
BUT....no use..because da seller is not jual da inlet manifold and throttle body. da ORIGINAL 2 item inlet and throttle body 1.5sohc cannot use anymore..
if u r from 1.5doch...yes..u can use back da 2 item (thro and inlet)...BUT..no point..because u r using 4g93 head..there need bigger throttle body and inlet manifold...
so..think before u buy.. :D
peace.. :D
I believe ur ride is power already but if you put a 4G93 head. you will feel more top speed
but you will lost ur pick up if you compare ur current 4G91 head and after 4G93 head.
I believe using a metal gasket will also improve the power.
kindly inform me if i'm wrong.
head size same la dudes..
4G91/4G92/4G93 heads Twin cam / DOHC heads are the same. Btw, i was saying about the DOHC engine variant la..
not the std 4G92P single cam or the 4G93P single cam.
The only difference is in the engine's bore and stroke, this is what u are refering to from the manual, rite.. So far, i have not come across a user car manual that specifies the head size yet.
No offence la.. just main main cakp aje tadi..
Hello dude,
No hard feeling again. as far as i know. you will get different power if you use a 4G91/4G92/4G93 head under the same engine block.
If you say all head is same size.. can you tell me why you will have power different with different head.
I really would like to know.
Hope you can teach me
okie .... let me do some explain ....
4G91 = 4G91 conrod + 4G91 piston smaller than 81mm + 4G91 head with cam degree abit different ...
4G92 without mivec = 4G91 conrod + 4G92 piston 81mm + 4G92 head ...
4G92 mivec = 4G93 conrod + 4G92 mivec piston 81mm + 4G92 mivec head ...
4G93 = 4G93 conrod + 4G93 piston 81mm + 4G93 head with abit high degree cam than 4G91
this is why 4G91 change to 4G93 head got the power different ...
If i'm not mistaken .. the height of the head also got abit different between 4G91 and 4G93....
pls correct me if i'm wrong ...
this head come from manual gearbox or auto gearbox ?? if I want to buy cam only , how ??
from my understanding, 4G91 could not plug in with 93 head ..... only can take the cam to plug in
bro, mine is 4g92p(of course sohc). can my current ecu, intake manifold and wiring be compatible with ur dohc head??
and bout the debate, wats the truth anyway?? 91-93 same head or not?? he he he
