4g91????
4G91 EFi has 115hp on flywheel...
Transplant cost is less than 5k... depending on how cheap u can get the halfcut for... i think some people managed to go under 4k also.
if ur looking for 4g91 halfcut n transplant we do it.. just contact me at 0123977870 or 0163585842 eattle.. when u transplant u can use back the ori gearbox..
thanks~~~~!!
but my play engine budget only 1.5K,wat i do??? so i get this n add weber.
if i doing like this how much i can get it the HP?? (4G91 CARB>>WEBER)
im not realy sure... but wat can i say... i dont think your budget should enought...
for my budget...
engine kosong (engine w/o gearbox) - RM 850
Flywheel 8" - RM 150
Clutch Plate + cover + bearing - RM 80++ (Exedy M'sia)
Webber DCOE (Twin Webber) - RM 600++ (Not realy sure... try ask unc fred)
RM 1680++ (Labour not included)
Labour charge + minor modification + additional item to purchase +- RM350 - RM1500
carb has 100hp on flywheel....
but is running s wee bit higher compressiong than EFI 4g91
carbie is 10 while the EFI is 9.5 compression ratio
this is some info about the engine i got...
4G91 (1496cc)
-Serial 4 cylinder DOHC16 valve, Electro- carburetor, NA
97 ps (71.34 kw) / 6000 rpm, 12.8 kg*m (125.53 N*m) / 3500 rpm
-Serial 4 cylinder DOHC16 valve, ECI-MULTI, NA
115 ps (84.58 kw) / 6000 rpm, 13.8 kg*m (135.33 N*m) / 5000 rpm
ENGINE
Displacement, cc 1496
Engine model 4G91
Max.power (Net), kw(PS)/rpm 97 ps (71.34 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 12.8 kg*m (125.53 N*m) / 3500 rpm
Power density 11.03
Engine type Serial 4 cylinder DOHC16 valve
Engine information
Fuel system Electro- carburetor
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) No
Compression ratio 1:10
Bore, mm 78.4
Stroke, mm 77.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.4
Fuel consumption at 60 km/h, l/100km
And mine car is 80% done... As i mention above, i've just transplan 4g91 engine to my girl. And it cost me about RM 2k. below roughly what i have done to my car.
by the way... im using Mitsubishi Lancer A172 (1.4cc SOHC 4G12) and my transmission is 5 speed FR Gearbox (Tarik Belakang one).
4G91 Carburator (Engine Kosong, W/O 450
Gearbox + Flywheel) RM 850.00
Flywheel 8" (Dunno the weight) RM 150.00
Megavalve Distributor 180.00
Need to workout with my long shaft RM 80.00
Buat Tapak Extraktor (Send to Mechine Shop) RM 60.00
Custom my extracktor (need to change from C to L) RM 150.00
Over All Labour Charge RM 450.00
Sub Total : RM 1920
rayracer said:
no 1 respon?
sowi bro... i dunno how much. even i buy engine lantai.. y dont u join 4g91 gang forum. many sify there. maybe they can tell u how much it cost.
as far as i know. my friend transplan 4g91 efi to wira cost about 3500 - 4000 inc halfcut + labour.
maybe u can join our TT next time. and u can ask them anithing about 4g91 engine transplan.
hehehe... woo wooo... im done with my car. but ive got temp prob with my engine. aniwan know wat it coz?
something new question,who know proton 4g93 single cam?? is tat engine can b fit in my car n used carburetor also?? n izzit can change to doch head??
whatever fuel injection engine u r look for, once ur ori engine is carb, u need to change ur exisiting wiring to efi one to support.
the best way is just look for complete half cut to convert ur car :D
mr racer, 4g91 carbie with installation and changing of old parts ie timing belts, oil seal all those is rm 1500 without jpj registration. direct fit into any wira or satria, except iswara or saga which do require some mods to one of the engine mounting.
thanks uncle fred!!
but now my plan is change to 4g93 single cam,but swap to carbie and dohc head!!
can ah?? or my original 4g13 change to any head can change??
