4g13 need advice
hapeace
hai taiko2,
can give some info to me, my car iswara 4g13p makan minyak hitam when long journey, normally i drive 150kmh at highway, but if i driving below 120km/h minyak hitam x makan.... need advice....
already check the engine no leaking and right now i using 20-50w oil engine...
some of my fren suggest to do top overhaul.... n some said to full overhaul...
if i do full overhaul can i rebore the block to 1.5 and how much the cost?
and can the engine tahan after rebore to 1.5?:wavey:
hai taiko2,
u just go and find 4g15 block better...cos 4g13 sleeve is thin...overhaul around 1.5k...
can not la..... punch block illegal la hehehe
already experince it when using motorcycle hehehe
so anyone can solve my engine oil problem....
need help.... taiko2 and sifo please help...:banghead:
if u dont wan to change to 1.5 block, jz do normal overhaul for ur 1.3 block lor...
brother sky, today i go to workshop, i ask them to do top over haul, then i ask them to install pipercam, but they say have to angkat enjin, change the gasket...
but i saw in your blog, the formen just plug in the pipercam... why aaa....?
wanna do top overhaul sure need to angkat head change gasket mahh.... my foreman jz change cam, i didnt do any overhaul...
no, i really need do top overhaul but alang2 they formen do top overhaul i want to install pipercam....
but when i ask him, he say to angkat engine, to change block gasket many other thing... and your car can be done 3,4 days after setting and other need to change....
but what i saw your forman just change the cam, no need to lift the whole engine.....:confused:
arghhh... vomit blood talking to u...
u said u wanna do top overhaul rite??.... if yes means u need to angkat head lor... angkat head means removing all the parts inside ur cylinder head for cleaning...
since u doing top overhaul (which gonna angkat head), jz ask ur mechanic to slot in the pipercam in for u laaa.....
Haha top overhaul really need to take out ur engine head and dismantle it to clean every single part. Therefore you can slot it ur pipercam when ur foremen installing all the parts back bro
yeah i know, brother sky and contreasjun27 but my foreman said, if i want to install the pipercam, i also need to lift the block gasket, lift the engine out to install it.... that waht the forman said....
sorry yeah new bie.... don't be mad yeah sky...:hmmmm:
try asking ur mechanic... if u jz wanna slot in the cam without doing top overhaul, still need to angkat head??...
if he say yes, pls whack him for me...
haha ok2 i will whack him....
sky after u use piper cam your FC is bad or very bad?
Cause u know that if your car become power, the FC will slightly decrease?
and What type of cam can be used, i mean their angle....
so many choice, 275 degree, 270 degree....
and between jasma and pipercam which one better..:adore:
I don't think it is somewhere 275 for a single cam .... at most 260 like that .... Stock cam is around 210 like that.....
Can you explain how the high cam work for us... it will be good info... which degree is better for pickup, which for top speed... and both... hehehe
Brother sky.... can help aaa for those info or provide us how 4g13 high cam work...:proud:
Just settle with ori cam. No point u get a piece of cam where u can't even alter both intake n exhaust cam timing. 1 get more power just swap engine. Tuning 4G1X engine just waste of money n time. Just my 2 cents .
you are wrong here bro...
not all ppl got the extra $$$ to opt for a better engine bro
and there is alot of strong 4G1x series engine out there who can really run bro...
there is a cam which is the Jasma Racing High Cam which I'm also selling it
it is a 275 Degree cam and it is not a regrind cam.
and it is proven that by just installing the high cam without any modification it can gain 8hp bro...
