4age 20v turbo kit!
chan kah jien
i have 4age 20v turbo kit wan to sell,ar50 turbo,thailand wastegate and bov,emanage blue wiz map sensor,81mm 4agze piston,vr4 intercooler,1jz 440cc injector,asking rm4600,location in kajang,urgent sell!
the engine have already overhaul at oct,after 2 week i take it go to bandar sunway run dyno and tune,make 269whp,but i think the engine can't tahan the power so now when rev it have noise,maybe the bearing or something...
---------- Post added at 11:08 AM ---------- 6 hour anti-bump limit - Previous post was at 11:04 AM ----------
piston(new 81.5mm) and conrod i use supercharge version also wiz big bearing and small bearing and full set ori overhaul kit,but still have problem...so i kecewa terhadap silver top...
saya rasa tidak,pasal waktu saya berhenti tekan minyak sampai 2k+rpm pun ada bunyi terkeluar dari engine,besar kemungkinan bearing crankshaft sudah bakar...
---------- Post added at 03:25 PM ---------- 6 hour anti-bump limit - Previous post was at 02:13 PM ----------
4age 20v turbo kit for sell,call 0166223040.
4age20 v turbo kit for sell..
you only can use emanage,blow off valve and wastegate,the ar50 turbo actualy like td06 size so tak sesuai untuk BOT,4age 20v +ar50 full boost 6000k rpm...very laggy.....
