4age 20v - 4 throttles
chloe111
guys,
how does the 4age 20v 4 throttles work?
at what rpm or what condition will all the throttle fully open ?
and how does each throttle synchconize open at what rpm range..
sort of curious la.. cos normal single throttle car the concept very easy and clear..
but 4 throttles.. i blur.. pls sifu explain a little bit for me... can??
:_: :_: :_:
chloe111 said:
guys,
:_: :_: :_:
Very simple,when u press the accelerator pedal,a cable connecting your pedal to the throttle linkage and opens your throttle,all 4 of them are open at the same time,you press more,it opens more,you lift off,it closes,even if did not start the engine(rpm = 0),it also opens if you step on the pedal,each throttle is interconnected to each other at the same axis.
sorry for the intterrupe. may i know how offen we need to service the four throttle, what type of service needed, if not service what deffect will happen and the cost of the service as well if posible. thanks.
any advice/info?:embaressed_smile:
meaning is it's purely mechanical .. u step on accelerator and the ITB will open according to how much you step ... doesn't matter if your engine is started or not ..
