450cc injectors
450cc injectors
Racedude
7,000 RPM
450cc and 390cc injectors
VR4 450cc injectors , RM200neg, Mirage 390cc RM170neg. Call 012-2338137 for more info. Thanks
Its been in my original VR4 since it was made in 1988, just upgraded to 510cc. No problems with them. can test on a injector tester in Puchong b4 purchase.
interested here bro..wats ur best price..?? pm me pls..very very interested..
aisey..u upgrade to 510 already kaa..?? i have one set of 510 for sale la..hehhe
You will need a resistor pack for your honda, these are low impedance injectors. Mitsubishi turbo engines have a resistor pack which you can use for your honda, unless youre using an aftermarket ECU that can drive the injectors directly using current limiting.
Hi,
I saw you mention 160 nett for self collect? Meaning?
Are this for the VR4 injectors?
I saw you mention as 450cc, but I thought VR4 is only 420cc?
I am interested if the price is right.
Do you want to turbocharge your mivec? These are low impedance injectors, you will need a resistor pack if you want to use original mivac ECU.
