4-2-1 Extractor for pickup or top speed?
MrKoo
Helloo..
i got abit confused one day when thinking of this...
4-2-1 extractor is for low end RPM pickup....
What about top speed? issit 4-2-1 extractor also affect top speed..?
Or open pod airfilter only can get better top speed..?
tnx...
4-2-1 is for low end rpm power...means mayb the powerband is at 2k rpm till 5k rpm.(just xample)
4-1 is more for high rpm power band...so mayb the power starts all the way from 4k till 8k rpm...
so if u dun normally rev tat high...just get a 4-2-1...
Hi Yong,
That what i thought at first, have you actually tried 4-1 yet? The thing is, all this time many friend have told me that 4-2-1 is good for city driving because of its low end power that it gives, and 4-1 were meant for track use because most of the power only happens at the top, but the funny thing is, when i was using the hot bits 4-2-1 system, is feel my power band was at 4k onwards all the way to redline, pulls strongly at around 5.5k, so i decided to be adventurous and go for 4-1, to my surprise the power was instant from low end, and it ended early too, perhap after 6k there wasn't much pull, by the way i'm driving a G2,
oh izit....but as u c...most 4-1 is use on mivec..vtec and the toyota 20v....all those r meant for high rev...
not sure wit hot bits 4-2-1 but i use powerzones...the power starts at around less than 3k then all the way to 6k
but anyhow...its just my butt dyno feel...didnt go dyno so i cant really tell it...
onli the torque graph will tell the truth...dyno wont lie...our feeling will...
erm...last time for my 4g15 is rm 400...of coz..at powerzone...
can try zenden 1 also mah...imitation of hot bits....much much cheaper sumore
zenden / hot bits / powerzone extractors the quality all same wan ar?
will installing center bullet affect performance..?
Powerzone 421 extractor compare to hotbits 421 extractor is it smaller in piping diameter, and the method of joining from the 4 pipes to the 2 pipes, obviously their design emphasize on overall performance (maintain drivability at the same time provide smoother air flow thus better performance), I try both powerzone and hotbits extractor on my previous engine, yes, hotbit provide better pulling power after 4000rpm while powerzone provide smoother power in wider range of rpm. but frankly speaking, powerzone abit pricy (RM450) compare to hotbit (RM340).
ethanphoon592, you are right, it all depend on the extractor design, last time I join WISE club TT, I saw on wira 1.3 fitted with 4x1 extractor (dunno wat brand but from my observation it is stainless steel, smaller diameter in piping, owner car with bullet plus s-flow muffler), I try to step on this gas pedal, surprising below 3000rpm it is more responsive then powerzone 421 extractor, his extractor design from the 4 pipes join to 1 pipe length is very long, until reach the connector of single pipe of conventional 421 extractor (are you try on similar design extractor?), but to be surprise, this 4x1 extractor after 3000rpm so so only
i dunno wat design my 4x1 extractor is.. but i noe 1 thing la.. my car is slow slow slow gah!!!! :mad: hahahaa.. no la not angry...
i think depends on luck la which extractor u fix .. whether correct or not...
anyway can someone answer my earlier question..? :smile:
Guys,
I don't deny the fact that Powerzone's extractor is giving good hp and judging the price they better be good, but based on my 2 cents, i think just go for any cap ayam brand is good enough already, some more they are using white pipe now, I used to use Hotbits headers for my G2, their 4-2-1, thankfully i got it from a friend of mine in Paramount garden for RM250, rather than getting it from speedworks RM340, i will say that, i dont know what hotbits people are doing because their flow is not balanced and its not right, as you can tell from this picture
http://i23.photobucket.com/albums/b359/ethanphoon/050917021418.jpg
Just look at the flow, firing order is 1-3-4-2, pipes 1 and 4 goes to 1 pipe and 3 and 2 goes to 1 pipe, so when the pistons are firing in sequence, you'll get a boxer sound effect when idling, no doubt this gives you a very nice sound effect but the power is not very good as compared to my friends cap ayam 4-2-1 with normal correct flow
http://i23.photobucket.com/albums/b359/ethanphoon/RallyAtSepang009.jpg
I saw Waja's hotbit extractor and it looks really good, but i'm not sure whether the gasket hole is the same or not.
ethanphoon592 said:
Guys,
ethanphoon592, since zenden and hotbits share the same design, I also feel weird how come from one of the zth forumer posted G2 421 extractor with pipes 1 and 3 join into one pipe, 2 and 4 join into one pipe in view gen2 firing sequence is 1-3-4-2, I have check with many exhaust shop, their explaination are, for engine with firing sequence is 1-3-4-2
pipes 1 and 3 join into 1, pipes 2 and 4 join into 2
more horse power
pipes 1 and 4 join into 1, pipes 2 and 3 join into 2
more torque
correct me if I am wrong
Wirafly,
I don't know whether its right or not, but if its true like what you said, then how come no other tuners like Mugen or Spoon practices this kinda flow? I just think that its weird to have this kinda sequence.
i thinik mugen n spoon onli comes out wit 4-1 xtractor rite...all those vtec high rev
but wat about dyno chart...ur fren 4-2-1 might be producing more hp for ur butt dyno but y not try dyno it...since the hot bits product is already tested n proven for performance
ethanphoon592 said:
Wirafly,
Yes, weird design, so far I only found 2 after market 421 extractor with this type of design, one for proton G2(zenden and hotbits), the other for Suzuki Solio in taiwan (brand something like EPN or EFN if not mistaken)
Yong,
Yup i guess the only way to find out is to dyno both extractors, basically a lot of sifus will tell you that 4-2-1 will be ideal for an instant upgrade from stock, and they will always guarantee that you'll feel something, but for 4-1 the bending of the pipes are very crucial, bend it wrongly and you will definately not get any horsepower gains, thats why a lot of first time owners of G2's when straight for Hotbits design because they had their dyno proven results, and most of them dare not experiment with cap ayam types, until one fine day some members experimented with it and once some one has become white mice then everyone broke the tradition.
halo...
my original extractor is 4-1
i change for 4-2-1 and the power is mid
once i shift to 2nd gear can feel the power comin until middle of 3rd gear
but...i just feel that original extractor is better
cause the cast iron can tahan high temp so the engine compressor wont drop
this is what my experience lar anythin wrong pls correct =p
anyway....do ZENDEN provide good perfomance??? then lastly with brand better.....or i think ayam brand oso can.......so the performance will gv us more 5%??? im using 1.3 iswara stock.....latst time a shop gv me RM150 for ayam brand....4-2-1.....izit lai det price??? do i buy form them
'';;;; any opininon????? :tee:
yes i also get mine at that price
my feedback is when engine is cool the power is there
when i drive for a distance then the power is decrease
it cause my engine compressor drop and reduce power
wat u mean engine compressor drop?
btw..for a cap ayam rm150...i rather pay rm 180 for zenden 1 since its also same as hot bits...
ori hot bits is selling at rm 300+
for cap ayam 1 they usin cheap material that cant stand for high temp
when the extractor hot the heat goes in yer engine directly
then cause yer engine compressor drop and decrease power lor
for original cast iron it can tahan very high temp
so it will maintain yer power well
this my my mech told me
and i also feel that lor
anythin wrong sifus here pls correct
