3rd GearPerformance HALTECH Pro series
But i heard only 1 P500 in msia owned by ACR736...
when i asked him,he said others r taiwan stuff...
and only aki and syah can tune pro series...
not only me can tune.Toby,Kamal,Din and everybody can tune and sell ecu.All Haltech ECU come from Haltech Australia:driver:
---------- Post added at 02:43 AM ---------- Previous post was at 02:38 AM ----------
Mivec Satria GTI
Pletinum 1000 PNP
1.8 block
Mivec Head
stock cam
Injectors GSR turbo
Walbro Fuel Pump
Stock ECU 147whp
With Pletinum P1000 161whp
Owh..tat mean he kenn me la..:mad:
like sum ppl...:banghead::banghead::banghead:
---------- Post added at 04:28 AM ---------- Previous post was at 04:24 AM ----------
Mivec Satria GTI
Pletinum 1000 PNP
1.8 block
Mivec Head
stock cam
Injectors GSR turbo
Walbro Fuel Pump
Stock ECU 147whp
Waa NA also use P1000...:love:
Anything u have direct email to Haltech and ask the Q.Better la.Pletinum series can control cantik la
Ask u better..hehe...:biggrin:
I have small knowledge.Out site there have a good2 tuner and he can give better answer.:biggrin::biggrin:
---------- Post added at 02:35 AM ---------- Previous post was at 01:24 AM ----------
Haltech Platinum 1000 Base ECU with Internal 1.5bar map sensor.Including Plug and Pin
Use Stock Factory Sensor. RM 5000
Haltech Platinum 2000 Base ECU with Internal 1.5bar map sensor.Including Plug and Pin
Use stock Factory sensor. RM 6000
Installation,Tuning and Dyno starting from RM800
All r the same la..mayb u need to handle and being urself...
Mivec Satria GTI
Pletinum 1000 PNP
1.8 block
Mivec Head
stock cam
Injectors GSR turbo
Walbro Fuel Pump
Stock ECU 147whp
Hmm..the LT10s on a mate's satria with 1.8 Mivec, stock cam, eterna TT injectors, stock fuel pump could get 165whp and that was not the optimum as engine was knocking like mad if ignition was increased. Would you have tuned it conservatively? Not comparing ecu but maybe the method of tuning between each tuner could be different..
Microtech good ECU but Haltech Platinum series can tune minimize and have 32 table for adjustment.And small trim for Injectors and Ignition.More funtion you can control.For me best power, best torque and reliable engine for street.Last time with LT8 tune with 100octane Mivec 1.8 engine have around 160whp and torque 147ft.Yes diff tuner diff tuning.
Thanks for the reply Syah.. i guess the tuner makes the difference and it could probably be also due to temperature and traction differences as well.
Btw, how much to install and tune sprint 500 on the Gen 2 CPS?
The price still same RM3800 including installation and 1hour dyno. no more charges...but some wshop offer STARTING FROM RM3600 and i confirm he spend over the price.don't compare with my wshop.i only small player.
---------- Post added at 11:24 AM ---------- Previous post was at 11:21 AM ----------
After tis all over in msia using haltech platinum..hehe...:biggrin:
Looking the budget and i advice which better
Hmm..1 hour dyno sufficient to tune optimally? Is it likely more than 1 hour is needed?
emmm....only aki,kamal, syah,din can tune pro series with genuine tune...."some" of it more to the bisnezz...pancing maa....:biggrin:
---------- Post added at 05:25 PM ---------- Previous post was at 05:23 PM ----------
that right... i will soon with sprint 500:driver:
My self,for Microtech just take only 1 hour if no problem from set up.If you know the 'KEY' tuning for haltech just take only a few hour and perfect on load dyno.If you are tuning the injectors 250cc to 1600cc and you know the press regulator,I think you know where to start.
---------- Post added at 02:16 PM ---------- Previous post was at 02:14 PM ----------
Have a good budget,choose the best:biggrin::biggrin:
Up date GTI mivec photo P1000
Gud2 support haltech pro series!!!:proud:
and more set up u can choose
Output Setup
Air Con Output
Air Temp Switch 1-4
Alternator Control
Aux Fuel Pump
BAC Main
BAC Slave
BAC Open
BAC Close
Battery Light
Boost Control
Cam Control Output 1
Cam Control Output 2
Coolant Temp Switch 1-4
Dual Intake Valve
ECU Diagnostic Light
Engine Control Relay
Engine Running Time Switch 1-4
Extra Injector
Generic Duty Output
Ignition Bypass
Intercooler Fan
Intercooler Spray
Intercooler Spray Advanced
Intercooler Spray Armed
MAP Sensor Switch 1-4
Nitrous Activation Signal
Road Speed Switch 1-4
RPM Switch 1-4
Shift Light 1-3
Staging Signal
Stall Saver
Tacho Output
Test
Thermofan 1&2 (PWM)
Thermofan 1&2 (Switch)
Torque Converter Lockup Control (TCC)
TPS Switch 1-4
Turbo Timer
VANOS
VTEC
Water Injection
GOOD PROMOTION with full information
not only for the best price promo
Sprint500 cash and carry RM3350
I'm interested on Sprint500..so what is the price including installation and dyno tune?
for ur information i'm running rb25det..can use that management?how many HP will increase after install that management?what is your advised? :driver:
