Temujin said:
i've been told nissans esp silvia's n skylines haf this prob, bad oil pump. perhaps u need to change to n aftermarket oil pump.
i currently dun haf that prob tho..
unfortunately there is no aftermarket upgrade for SR20 Oil Pump... i don have that problem even with Oil Cooler add on also... perhaps ur using wrong engine oil vicosity OR.. ur Oil Pump is not in good condition already... suggest that u replace it with NEW Oil Pump instead...
PS13 said:
hi all..i own silvia ps13..i like to share with u guys with my sr20det 's problem..i've chg my engine twice..the oil press too low because of oil pump prob..pls help me..anybody facing this prob?
Do you have an oil cooler? I suggest you hooking up an reliable electronic oil pressure gauge with warning features that can warn you in case of oil pressure drop. You can also try to install a bigger oil sump just in case your oil starvation problems comes from failure of oil pickup. You may use the oil pump from the gtir or the VEs which will produce higher pressure, but some customisation might be needed.
Fuwah...Leona very farnee ah nowadays hehe. U changed ur rims edi? So that day the clear lights how? Got it?
Regards;
I don't have oil cooler.Is it can cause oil pressure drop?Do you have any suggestion on which one I should go first?For your info, the oil sensor signal will appear about 15~20 mins. Then it will gone. There is one more problem happened to my SR20 a few days back until now, idling timing too high 1500rpm.I checked the mixer valve(??) and throttle body but the mechanic said still good. Is it any problem with my ECU?Thanks so much
Yes oil cooler installation will cause oil pressure drop. If you don't have an oil cooler, then you might need to look into other issues. Such as, a blocked strainer, faulty oil pump, damaged oil sump, faulty oil pressure warning switch maybe...
High idling might be caused by a few things. Get the ECU scan for fault code 1st, then only start to look into others such as TPS, AAC valve etc.
What car you're driving? Who is your mechanic?
Thanks for your advise.I'm driving silvia s13.Normally i'll send my car at Setiawangsa(mechanic's name Penang).
It seems everyone so busy laterly. So quiet out of sudden. Anyhow, how's life ppl. DOing good? Me so so. Currently modding my 6 speed to Nismo gear and stuff like that. Is going to take foreever I guess, so currently no car to use. Hopefull this will done up soon. BTW, any TT session laterly?
December 1st lol.. we will have a short one... :)
