2005 Mini Cooper S
davidcnz
TECH SPEC
2005 Mini Cooper S
Engine
Fireballed! Racing Mad Mod head, intake manifold and fuel system, Garrett GT3071R turbo conversion, JE pistons, 75mm throttle body, water-to-air intercooler, HKS SS blow-off valve, Powerflex motor mount bushings, 3" exhaust with dual A'PEXi N1 black tips, 3" catalytic converter, Nology cool wires, XRP plumbing, Meziere water pump, 75-shot nitrous oxide, A'PEXi Afc
Drivetrain
Six-speed manual with Exedy clutch and flywheel, Quaife LSD, B&M short shifter
Suspension
Bilstein PSS9 coilovers, R-Speed 22mm rear sway bar, H-Sport front bar and upper and lower camber links, adjustable end links, front and rear strut braces, M7 under strut brace, Powerflex control arm bushings, urethane rear strut bushings
Brakes
Ireland Engineering brake kit with brass bushings
Wheels & Tires
18x8" Axis Decade wheels, 215/35-18 Falken FK452 tires
Exterior
Painted fenders, smoked grille, headlights and tail lights, Oriciari cowl vents, GP rear wing, carbon front splitter, OE Aero side skirts, shaved wiper arms
Interior
Recaro seats, leather shifter and e-brake boot, Whalen shift knob, JCW leather dash and down tubes, four-point roll-bar, OE European parcel shelf, Turbosmart e-boost 2 boost controller, Defi Link boost and fuel pressure gauges, Innovate IC-1 wideband controller
