2 Way comp. VS 3 Way comp
avaTHara
Sifu's,
Was surfing DLS web. They have 2 type of comp.
1. 2-way system
2. 3-way system
which is better and the best for the ICE beginer.
3 way......
thsi setup will be hard, u haev to get ur placing right & make sure
u have the right speakers for ur self...
not to forget 3 way give u all the frequency from every parts of music & u cna here the seperation very well & nicely assemble........
btu to get in to this level, u must be know ur setup so well that even anyone simply ask u how it sound ..u must know how to explain it
2 way....
way 2 simple & very not much seperation & dynamic....some speaker
have them.....u also can get good sounding with 2 way....an easy setup no hassel & havoc...just get the placing right
tune a bit & u got a nice setup for ur ears......
ADVICE: If U cant go there, dont force it ... just K.I.S.S.
It all depends on the comps itself, space for the installation and most important of all, the tuning.
With the 3 way, there's the extra midrange which acts as a "bridge" to fill the gap between the upper mids for the midwoofers and the lower high frequencies from the tweeters.
If you're using the passives, 2 or 3 way shouldn't matter other than driver placement.
It only starts to gets difficult when you decide to go active.
what if i say, I dont have that much money to spend on and then spend for upgrade later in the future. How right if i choose to go straight to 3 way and start off there? save for the future upgrades? since you all say start with 2-way, then only then slowly to 3-way, can beginners even start with a 3-way system?
Can.. no one will stop if you go for a 3-way system.
Just that as 3-ways are more difficult to tune and get right, you may lose interest and get fed up quickly. Also there are more things to conside when doigna 3-way such as mounitng and speaker placement is more critical, things which you wont fully understand yet.
However, you can buy a 3-way system and use it as a 2-way first. Once you understand what you want to achieve and some basics on tuning, you can easily install the 4" midrange.
yup. fully agreed with Bert. With 3-way straight, u may not able to understand the foundamental and the concept right. u will need to start frm low. knowing basic tuning, freq, xover and speaker positioning.
4" is merely to drive the high mid range freq only. Or should i say Vocal? hence u do not need to have big like midbass. normally plp mount it nearest to tweets.
