2.0 L 3S-FE VS 1.8 VVTL_I 2zz !!
FE series of toyota eng is not performance engine.....if u compare 2zzge and 3sge more equal..... :biggrin::biggrin::biggrin:......and to answer ur question 2ZZ faster......:biggrin::biggrin:
:thefinger: HAHA!! i know u like kidding !! :thefinger: 2zz can win 3sge ?!!
TOMS ! NICE TO MEET U !!
WHEN U CUM TT !! PLSS INVITE ME !
CHEERSS !!:burnout:
i also would like to know the outcome of 2zz vs. 3sge......
1 question on 2ZZ
any1 use b4 power fc on 2ZZ??? can it control the vvtli open earlier??......last time i test drive a few 2zz and it open only at 6krpm,,,,correct me if i'm wrong......
yup...
open lift when 6k...
but..i heard b4..our ccm hv 1 celica turbo...lift hit at 5k...
tat's mean...turbo 3 k open...5k lift open !! :biggrin:
Yep, you can start by comparing 1ZZFE with 3SFE
PS:The ZZ family of engines is co-developed with Yamaha
there are a few 2zz guys running on pfc..... some running lower Lift point and some higher... depends what cams you are using... pfc is meant for manual only but can be hooked up with Brashboy harness to the auto 2zz and work as a piggy back.....
nope... there are a couple of 1zz in M'sia... 90% of S'pore celicas are 1zz.....
1zz=GT=vvt=zzt230
2zz=GTS=vvtL-i=zzt231
1zz fe = toyota
2zz ge = built by yahama for toyota (specs goals give toyota)
there is SAE paper on this.
on HP ~ 3SGTE (boosted) > 2ZZ ge (NA) > 1ZZ fe (NA)
& yes there are some who used PFC to lower lift point, but no gains.
engage in 6K rpm; dissengage 5.5K rpm
koolsyda... I do know some ppl who benefited from lowered Lift point..... on the contrary, my lift is set at 6500rpm... :)
