1992 Ford Telstar Problem
leros
Hello guys,
Would like to enquire in anyone could assist me in this new symptom that i encountered with my ride. I drive a 1992 Ford Telstar 1.8 Carb (8 valve) and lately after my last service which was done last week, i notice that that the warning lamp for "Washer" which is placed on the instrumental cluster is on. My first assumption was that my washer tank was empty, but its not. I then tried to activate the washer and the washer fluid is pumped out normally. But the one that baffles me is that why the light is turned on. It is on the moment i switch the engine on and till i switch the engine off. Anyone who has any idea with this, please help. It is very irritating to see the light on for no apparent reason. Thank you.
hahah...ok...
it's your washer pump sensor. i had the same problem and i had to replace my washer pump.
Problem Fixed
Yes Sudha,
I had got the problem fixed a few days ago but was too bz to post it here. And yes, it was the sensor in the washer tank that was faulty. Thanks anyway. Regards.
