15" rims on a kelisa..
over
I wanna install 15" rims on my kelisa, with stock suspension, izzit ok? meaning using it without any damaged to other part coz a fren of mine install a 15" rims on his tiara, every 2 months have to change tyres (tyres sangkut to body). So anyone whose using 15" rims on his/her kelisa would like to share ur experienced??? some say its ok if u mod the wheel arch and use stiffer suspension......but.......some doesn't recommend at all....hmmmm....help.
nope...u must get your fender knock...if not..the tyre will hit the fender everytime u turn corner or take more the two passenger....
u need to add bush between the spring to make it higher...the best is change ur suspension setup....
using 15" will kill your top speed and also ur pickup...15" will just give u the look of lowered and VIP...
your FC will also increase..the best is 14" best for our car...
hmmm... i think ur rite...but the 15" rims i wanna buy iz light weigh alloy...from italy forgot the brand...but very light....so maybe my top speed n pickup will not be effected so much.
Actually there are 15 incher for k-car where their width is 5-5.5 inch. Those sedan 15 inch rim is around 6-8 inch where 7 inch width is most common. If you want to get 15 incher to fit your kelisa without knocking anything. Get the right spec rim.
ic...so wut iz the right spec for kelisa
If lightweight rim than the effect will not effect much on the pickup and top speed….but I think u need to do a lot of thing to get the 15” rim into your car…like add bush in your spring and also use low profile tyre…
the usual spec will be offset 38-45 and the width is 5"-5.5"jj.:regular_smile:
Thats mean is like this 165-50-15 for tyre like Toyo MP Sport and rims is 5.5"jj x 15" with offset 38 to 45 just choose one.
The tyre + rim expert has spoken….
i m newbie in modding, expert rank belong to all the taiko here like Kelisa6009,Bob6009,k-Kid taiko,Butty etc, i m oni a butler nia :laugh:
lets Hail Bob Taiko The Sport Rim King!
:adore::adore: :adore::adore: :adore::adore: :adore::adore: :adore::adore:
back to main topic, if you want those wheels to go more outside like a 4wd, get those with offset lesser number.
if using the 4wd..u need to cut the body and use bigger wheel arch then only u can put this type of rim...it will be very heavy
well,if u just want to have the looks like one,just get a wider wheel with lesser offset will do but how much lesser will depend on your rims spec.
