1 Layer Alu Radiator vs 2 Layer normal Rad
FGT
Brothers...which one is better? Need your wise opinions..
In terms of price, aluminium rads are more expensive but does a 1-layer aluminium radiator disperse heat as efficient as the 2-layer copper radiator??
I also come across some people saying that if the engine block is made from a different material (not aluminium), it will cause corrosion inside the aluminium rad. Consequently, it results with clog and rust.
So, what do u think? I hope u can share your experience using aluminium and copper rads for your beloved toyotas?
Thanks..
topic revive....!!! not really.... heheheh
actually i just wanna find out, GZE radiator, the top water jack and bottom is at which side? anyone know?
