1.5 to 1.8
ashraff
hi
im currently using wira aeroback 1.5 to mod with 4g93 block + mivec head + MMC ecu
.is it ok or the machine will giv problems to me in future.
bro,
if its done properly,it shud not give u problems.i have a buddy who has done it and its running till now without any problems.his running,on mivec head,ori mivec wiring and ecu also with mivec gearbox except for the 93p block(unsure of what kinda piston) la....oh yea,had to use i guess t/supra timing belt...but unsure of which model its from.
happy modding and all the best to u!
Problems in future?
No, if u Have the Mivec Complete wiring n ECU +VAFC
Yes,If u dont have them all
VAFC not necessary... go get a rechip for the 1.8 mivec map.
1.8 mivecs are quite common already... the mapping for them shouldn't be too hard to find. I'm sure a lot of workshops can do.
oh...means u gonna put in a 93 then change mivec head and all laa correct kah??
can why not, many already done.
bro... do u change ur piston into high compression piston? Original Mivec r coming from high compression piston... It can help to increase ur HP~
