Wheel spacer : pros n cons?
+3 is not that far out..
If -10 that's far.. Like my KE70
I've done my Levin.. Using long studs n 2 spacer per tyre..
i didn't remember my rim offset.. So, couldn't calculate d offset :biggrin:
That is why I ask using FWD or RWD?
If RWD offset normally close to zero or in negative offset.
Some FWD at +35 already scrubbing rear fender
If your rims are positive offset at +20, adding spacers to make them come out you will have to minus, means +20-17= +3 offset. This means your wheels are pretty far out. Are you on FWD or RWD?
ah yess...always upside-down with that calculation....
but i would say my tyre were flushed within the arch after the arch folded in the inside....
