stronger battery but original motor
audiolizard
just start playing electric RC ..
my question
can i put a 5000 battery in a original motor?
my RC brand is from china VANTEX
will the 5000 battery cause my motor and ESC to burn out?
appreciate sifus help...
there is a probability (1/10) that ur esc will kong...heheh
ur motor will only heat up due to longer play time.
u also will feel more punch when using the 5000mah battery than the standard battery.
Its perfectly ok 4 u to used the above combination but for the safe side making sure to checking your motor every 3mins. Also, if your battery is NiMh with 7.2v, your stock motor have longer life span but if the batt is LiPo with 7.4v then your motor will have shorter lifespan due to higher voltage. But u will have higher top speed. The run time also affected by altering the gear ratio, weight of the vehicle and type of tire used. Just my opinion.
