Hello DCM members
For sale is a New Shift Lever Bush for Sr20 mission.
Its a new bush replacement from too much freeplay
Hard Bushing for better shift feel.
its for the replacement of original worn bush.
Selling for rm80 per piece only
Thank you.
You are viewing a Brand New Diff Mount Rigid Collar Set
Diff Mounts are much stiffer than the stock rubber bushings (Aluminum composition) and give
an increased feeling of overall stiffness to your ride. Traction will be increased and lap times
can be improved as well. Made of Aluminium material
First 10 set , selling at introdution price rm 250 set
BRAND NEW transmission mount S13 S14 S15 Silvia
Stabilize your Nissan`s transmission to properly transfer the power made from the engine to the
rear wheels without losing any power like you would with a shaky stock mission mount. These mounts
won`t fall apart as easily as OEM stock. Made of Aluminium material
Tachometer Selling Rm350nego... Original Autogage
Thank you for viewing
Thank you.
