Squeaking? Peculiar case.
My Neo also has squeaking sounds, during all upshift / downshift -- caused by friction on the clutch pedal.
It's hard to gauge what 'squeak' are you referring to bro. A video / sound recording would help.
i have the clutch pedal squeak too! Do you know of any way to oil/grease/lub it? haha
when was the last time you change your gearbox oil? try replacing the gearbox oil with penzoil.. several of my neo friends swears by it.. shifting gears is smooth as silk and the gearbox doesnt squeaks as much.. :)
When i shift from any gear to 2nd gear, it feels stiff n doesn't want to go in easily sometimes.. will changing to better gearoil helps? ( It is like this before and after changing of the gearoil )
