Saga LMST
Hi, i'm a newbies in this forum. I have Saga II/LMST a.k.a kereta kebal year 2004 black one. I've one problem, my interior roof lamp no power supply. It start with my cigerette switch short circuit and all off acc not function. I take out my cigeratte switch and all acc function as normal. But just one, my roof lamp not function. I've check power and that's problem. No power supply. I tried to loop my roof light through door switch and the lamp function as normal. But I want to use the original wire. Can someone reply to me where is the power supply come? I've check all fuse and every fuse ok include spare fuse inside dashbord.
Jaywat, i use the same car and got the same problem. I found that the back-sit iron rod problem(the metal lock the back sit in position ) . i try tape the rod with tape (any tape) and solve my problem.
Other sound from the door (back dook) locking , sometime got sound the sometime no loh . . . . but can be solve by adjusting the locking hook (the hook with black rubber). :mad: if u bring back to proton , they will tell u everything is find , no problem found. :mad:
I just use wire tape. It most longer than other tape. Now about 3 years. I put back wire tape. Yeah, no more squick2. Hahaha
