@DNGFashion
So you’ve tested the M4RS but not the FK8CTR
If you like the M4RS, then you’ll love the CTR just as much at the very least.
Since you mentioned pure driving, I suggest you also try the Megane 3 RS if you haven’t.
I heard the Megane 4 RS Trophy is coming to Malaysia like very soon as well, FYI
The CTR edges over the M4RS in almost every aspect, as it should since it has bigger of everything.
CTR is easier to drive, When in town, it’s practically like a manual version of the 1.5L turbo civic.
The manual transmission is also easier to operate in the CTR, take zero effort to be smooth.
It’s a complete, refined, mature daily hot hatch.
Megane 4 RS feels more demanding. The quirky clutch and shiftknob alone will require a couple weeks to master.
It’s not the easiest car to drive smooth and fast, so it’s rewarding because the longer you drive the more personalized it becomes. Seating position is higher compared to the CTR but the overall cockpit feels more special, more european, less familiar like a Civic.
Chassis wise, they both are right up there although again, it’s easier to access the CTR’s limits than the Megane. The CTR has adaptive damping which is hard to resist, comfort wise. So if you feel that dilutes the experience, then the Megane’s fixed mechanical dampers means it’s perpetually a real, no nonsense hot hatch. They are both heavy duty on the road, takes bad roads like a champion, but the Megane is just a little more hardcore every time.
I wish too as well, but often times they require a certain amount of money to be put down to test drive. For me, I have my reservations on that practise.Why not test drive some of the used or recon FK8R? Got many on sale right?
Good to know that, but is M4RS Trophy 300 or Trophy-R?
Yes, you are right that I've tested the M4RS and not the FK8CTR. I will try the M3RS if there is any wiling owners ;)
Noted of your feedbacks. Yes, I agree with you that M4RS has a rather steep learning curve to realise its limits. On the quirky clutch, I wasn't stuck in day to day traffic to feel it. But I guess, Honda has the win for their MT gearxbox all times.
The M4RS turbo pushes rather hard at 2k to mid rpm range, however, does the FK8CTR turbo behave in such manner?
How does the rear torsion beam compared to the rear multilink suspension?
How does the 4control affect the character of a FF car, in your experience?
Trophy 300 if i'm not wrong
Yeah, the M4RS pulls hard from for a 1.8T, has strong mid range from 2K like you said. The CTR is less exciting in terms of engine character, is very linear throughout but still faster overall.
CTR multilink probably feels more assuring in the fast bends, especially our b roads, better overall grip, versus Megane torsion beam, which can be more fun, more dramatic, more chuckable. But hardly felt difference in ability under normal fast driving.
4Control is a mouth watering concept, but wasn't particularly impressive in real life, didn't actually notice significant advantage at least in genting highlands. It's nice to have, does reduce turning circle significantly in city driving, u turns, carparks
got to say it's hard to resist the Megane even just based on looks alone
I will be also taking the purchased car for occasional track sessions like 3-4 months once, do you foreseen any major mods to be done for that purpose?
Yeah man, the outlook is something to drool over for a hot hatch. Also, M4RS is not a thief magnet, which is also my biggest drawback on FK8CTR given that I will be daily driving it.
Oh great, I was actually searching for the Trophy 300 with much keen. Maybe I can ask TC people again ;) thanks for the tip.
And my last question, is there any disadvantage between these 2 cars in your experience?
If I were you it's a no brainer between the 2 I'd pick the Megane anytime any day over FK8R purely from the look!thanks all Sifus..that really make my day.
Yes, TC is bringing the Trophy 300 this year.
yeah this is probably a better, more cost effective route, I had a water meth kit in my previous clio rs before considering an intercoolerI'd actually suggest just water/methanol kit first before intercooler upsize if still just using stock turbo. Bigger intercooler can be more laggy. If you install water/methanol kit, then can check the intake temp drops, so might not need bigger intercooler, hence can still maintain stock response.
got to say the stock evo intercooler is a lot bigger than the micro sized ones on european hot hatches, for example here's a Megane 3 RS stock and aftermarket comparisonI still use stock intercooler on my Evo despite bigger turbo, no problems with temperature whatsoever cuz I use water/methanol kit.
Oh those are pretty small ya. Really designed to maximize space and response. Can setup the water/methanol kit to activate sooner with bigger injector to compensate more, just that the fluid consumption will be higher. Good idea also to upgrade to a bit bigger intercooler.yeah this is probably a better, more cost effective route, I had a water meth kit in my previous clio rs before considering an intercooler
