recommend miniDSP's nanoDIGI_2x8-B
Acoustic
Hi guys,
I recommend this miniDSP's nanoDIGI_2x8-B
I'm using one at home now. Later in the future will run in car. It can run off 12vDC. >10 years ago already running below in my car using invertor. no limits - pro audio DSP in car 2003
Since nanoDIGI_2x8-B is digital outputs only, couple with pure digital driver (direct digital amp = power DAC) [no DAC inside]
something like
http://detail.1688.com/offer/42455189377.html?spm=a2615.7691456.0.0.BBmEdF
or
https://world.taobao.com/item/43291747349.htm?spm=a312a.7700714.0.0.Tjx8NU#detail
They run as high as 36vDC hence need DC amplifier to convert upstage.
then system setup as this example good example setup - Hi-Fi - orthodox
Wait.. yours is a DSP?
Sorry.. You're right. Not same thing at all.
Right now I'm using the Tunebox connected to a Bit10 using optical which is a DSP. Close enough :biggrin:
